Just did an upgrade and now Lutris wont open.
Tried to remove it, reinstall it and it still wont open.
Please help me thanks all.
Kernel: 6.3.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=fb4f8752-5778-428b-984d-80e7a1caddca rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: Micro-Star model: MPG Z390 GAMING EDGE AC (MS-7B17)
v: 2.0 serial: <superuser required> UEFI: American Megatrends v: A.70
date: 01/02/2020
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF8
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3899 high: 4802 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3600 2: 3600 3: 3600
4: 4802 5: 4800 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600
13: 3600 14: 3600 15: 4792 16: 4800 bogomips: 115200
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f06 class-ID: 0300
compositor: gnome-shell driver: N/A note: X driver n/a, try sudo/root
display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-0 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x12.99")
diag: 865mm (34.07") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Sony DualShock 4 [CUH-ZCT2x] driver: usbfs type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.3:6 chip-ID: 054c:09cc
Device-4: EVGA NU Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 3842:3100
class-ID: fe01
API: ALSA v: k6.3.5-zen1-1-zen status: kernel-api with: aoss
Device-2: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9
address: <filter>
Local Storage: total: 10.44 TiB used: 636.95 GiB (6.0%)
model: WDS100T3XHC-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Zotac model: ZTSSD-A5P-480G-PE
tech: SSD serial: <filter> fw-rev: 01.6 scheme: GPT
model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
model: WD4003FZEX-00Z4SA0 size: 3.64 TiB block-size: physical: 4096 B
used: 636.95 GiB (68.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.74 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 57.0 C mobo: N/A gpu: nvidia
temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 392 Uptime: 15m wakeups: 1 Memory: available: 62.74 GiB
used: 6.74 GiB (10.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1512 libs: 467 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2023-06-03 ↻
