I installed the ultimate version of deepin and like all the garuda distros it has vulkan support, only that lutris is not recognizing the vulkan and because of this epic games does not work, how can I do recognize the vulkan API in lutris?
This didn’t solve anything.
give us out put of
inxi -Fxxxza
also
ls /usr/share/vulkan/icd.d/
Same issue here!
inxi -Fxxxza Output:
Kernel: 5.8.5-zen1-1-zen x86_64 bits: 64 compiler: N/A
root=UUID=ccd3c6a9-129a-458e-b62c-2b63753ffc2c rw rootflags=subvol=@ quiet
splash resume=UUID=18a794b8-6155-481c-af0b-b699752d58da loglevel=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: Acer product: Predator PH315-51 v: V1.26
Mobo: CFL model: Sienta_CFS v: V1.26 serial: <filter> UEFI: Insyde v: 1.26
date: 03/27/2019
ID-1: BAT1 charge: 39.7 Wh condition: 39.7/48.9 Wh (81%) volts: 16.8/15.2
model: LG PABAS0241231 type: Li-ion serial: <filter> status: Full
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10)
microcode: D6 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 36799
Speed: 4000 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 4000 2: 4001
3: 4001 4: 3941 5: 4000 6: 3983 7: 3999 8: 4001
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 450.66 bus ID: 01:00.0
chip ID: 10de:1c20
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus ID: 1-5:3
chip ID: 0408:a060 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.8.5-zen1-1-zen
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
v: kernel port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 07:00.1 chip ID: 10ec:8168
IF: enp7s0f1 state: down mac: <filter>
Local Storage: total: 2.74 TiB used: 410.03 GiB (14.6%)
ID-1: /dev/nvme0n1 vendor: Intel model: MEMPEK1J016GA size: 13.41 GiB
block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
serial: <filter> rev: K4110400
ID-2: /dev/sda vendor: Samsung model: ST2000LM007-1R8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: ACM2 scheme: GPT
ID-3: /dev/sdb type: USB vendor: Samsung model: Sony Hard Drive
size: 931.51 GiB block size: physical: 512 B logical: 512 B
serial: <filter> rev: 5438 scheme: MBR
Edit by Mod: Please use </> for terminal output
Remove
sudo pacman -R vulkan-intel
