Hello, I am trying to use the Lutris app to play some roms but it keeps saying that it can’t identify my Super mario Galaxy rom and a few others, how do I fix this?
Just use RetroArch.
Also read and follow the post template. (post garuda-inxi , etc)
Please explain your problem a bit more clearly
Lutris has only been able to identify roms for the gameboy and ds
You install it from aur ?
Please run garuda-update in the terminal, update your system and reboot .
If this doesn’t work then reinstall lutris from octopi .
If this doesn’t work then uninstall current lutris and try lutris-git from octopi.
See and tell me.
