Low Wifi Download Speed
I’m trying to fix this issue for days but couldn’t resolve it. I installed the Garuda couple days ago. Everything went fine until i tested out my network speed. It’s quite low. 30mbps at max. I tried the every solution in the forum. LTS kernel, iwlwifi.conf file etc. but nothing helps. Can someone help me out ?
What’s normal for you?
Bit and Byte problem?
Did you try other PC, phone, …?
ISP problem?
Welcome to the Garuda forum @loaanvulon. :wave:
The “I tried everything” type of comments are of zero benefit when troubleshooting remotely. We need to know exactly what you have tried in painstaking detail.
If you tested driver options via an iwlwifi.conf file we need to see the output using the cat command of all options that you tested.
Did you test all the following driver options?
options iwlwifi 11n_disable=1 swcrypto=0 bt_coex_active=0 power_save=0
options iwlmvm power_scheme=1
options iwlwifi d0i3_disable=1
options iwlwifi uapsd_disable=1
options iwlwifi.disable_11ax=true
Did you reboot after each driver option change?
Did you test other kernels than just the LTS kernel?
I would suggest testing at least the linux-mainline kernel as it incorporates the most recent updates to your intel WiFi driver.
We also need log excerpts containing any reference to iwlwifi or NetworkManager errors.
