I just migrated from windows 11 to garuda and the experience is great!
but I have issues with sound. Its the same type of problem with sound before installing realtek audio driver in windows. I saw on youtube and tried alsamixer but nothing changed. Thank you in advance!
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=ccb48291-187b-4c25-aeca-be33387526a5 rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: H310M H 2.0 v: x.x
serial: <superuser required> UEFI: American Megatrends v: F12
date: 08/13/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 3811 high: 4001 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 3711 2: 4000 3: 4001
4: 4001 5: 3157 6: 4000 bogomips: 34798
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 mapped: HDMI-A-1 model: Acer QG221Q serial: <filter>
built: 2020 res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.44.0
5.16.14-zen1-1-zen LLVM 13.0.1)
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 689.33 GiB used: 17.83 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
type: SSD serial: <filter> rev: R013 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: SC13 scheme: GPT
used: 17.83 GiB (8.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 806
Processes: 305 Uptime: 35m wakeups: 0 Memory: 15.57 GiB
used: 3.8 GiB (24.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1780 lib: 524 flatpak: 0 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-14
Last full system update: 2022-03-14
