Why I do not know .. I am new on Arch base Linux .
Welcome ![]()
Read again the template, please.
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
"Welcome garuda" inside icon app it is not showing icon quality at good
anyone know the reason . but all other app icon is showing good quality .
some screenshot
i just try to ignore because not a big deal but it is looking bad each time i open .
Kernel: 5.17.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=244527e9-1a36-46bf-a50d-982f4ffa90b8 rw rootflags=subvol=@
Type: Convertible System: LENOVO product: 81X2 v: IdeaPad Flex 5 14ARE05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: EECN36WW date: 05/17/2021
ID-1: BAT0 charge: 39.1 Wh (73.8%) condition: 53.0/52.5 Wh (100.9%)
volts: 12.0 min: 11.6 model: LGC L19L3PD6 type: Li-poly serial: <filter>
status: discharging cycles: 498
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1642 high: 2178 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2161 2: 1469
3: 1339 4: 1685 5: 1269 6: 1645 7: 1394 8: 2178 bogomips: 31940
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1636
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 5986:212a class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1406 built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.8-zen1-1-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
snd_pci_acp6x, snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.17.8-zen1-1-zen running: yes
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
IF-ID-1: vboxnet0 state: down mac: <filter>
bus-ID: 3-4:4 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 28.32 GiB (5.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVME 512G size: 476.94 GiB
type: SSD serial: <filter> rev: T1102A0L temp: 35.9 C scheme: GPT
ID-1: / raw-size: 417.15 GiB size: 417.15 GiB (100.00%)
used: 28.32 GiB (6.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 8.7 MiB (2.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 417.15 GiB size: 417.15 GiB (100.00%)
ID-4: /var/log raw-size: 417.15 GiB size: 417.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 417.15 GiB size: 417.15 GiB (100.00%)
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: swap-2 type: zram size: 7.2 GiB used: 1.53 GiB (21.2%)
System Temperatures: cpu: 43.0 C mobo: 41.0 C gpu: amdgpu temp: 41.0 C
Processes: 304 Uptime: 2h 14m wakeups: 4 Memory: 7.2 GiB
used: 3.91 GiB (54.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1574 pacman: 1567 lib: 380 snap: 7
Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.15
Garuda (2.6.3-2):
System install date: 2022-05-18
Last full system update: 2022-05-19 ↻
Topic subject edited for better precision/understanding.
Instead of uploading many images, could you upload one that shows exactly what problem you are referring to?
any icon on garuda welcome app .. not showing well icon .not clear icon i means .but i tried doing of global scale (100%) .. it show clear photo but too small for my eye
What scaling are you using? How have you set that value?
i did not understand that .
OK, so you're using a scaling value where any bitmap image will show the same issue, as the image pixels cannot align to the display pixels.
This isn't an issue with the Garuda icons.
ohh that means it does not had any solution ?
Correct. Compare the value you're using with 133%, 150%, and 200%. Some will look better than others.
