I am attending online lecture for 2-3 hr or doing anything in my laptop when battery low approx 15% it shutdown automatically without any notification
Hi there,
Please share output of
As text, enclosed in ~~~
I can’t check on my system at the moment, anyway, I found something interesting searching on the web.
You could try to check if this behaviour is triggered by upower.
There should be a file /etc/UPower/UPower.conf with some parameters to check, like PercentageLow and PercentageCritical for notifications, and PercentageAction to shutdown.
I don’t know if this is the real culprit, because you should have had notifications, but at least if you have PercentageAction=15 that could be something to test.
These are my current (and default) values):
PercentageLow=20
PercentageCritical=5
PercentageAction=2
garuda-inxi may be found in the following packages:
chaotic-aur/garuda-common-settings 2.5.3-1 /usr/bin/garuda-inxi
chaotic-aur/garuda-common-settings-git 2.5.3.r0.g8e5b36b-1 /usr/bin/garuda-inxi
my default values
PercentageLow=10
PercentageCritical=3
PercentageAction=2
today also same watching youtube at fullscreen no records of time and suddenly laptop off
when i plug powercable and start it show 22 % percentage so i think it off 0n 20% automatically every time
Your system is not updated since a while.
Enter update in terminal. This will update your system and make available garuda-inxi.
update may be found in the following packages:
community/gitlab 14.5.2-1 /usr/share/webapps/gitlab/bin/update
community/gitlab 14.5.2-1 /usr/share/webapps/gitlab/vendor/bundle/ruby/2.7.0/gems/bootstrap_form-4.2.0/demo/bin/update
community/mailman 2.1.39-1 /usr/lib/mailman/bin/update
chaotic-aur/android-sdk-platform-tools 31.0.3-1 /opt/android-sdk/platform-tools/systrace/catapult/dependency_manager/bin/update
chaotic-aur/garuda-update 1.8.5-1 /usr/bin/update
What next ?
This means that you still have to add chaotic-aur in your pacman.conf adding
[chaotic-aur]
Include = /etc/pacman.d/chaotic-mirrorlist
If you want, you can reset the whole pacman configuration with
sudo bash -c ". <(wget -qO- https://gitlab.com/garuda-linux/themes-and-settings/settings/garuda-common-settings/-/snippets/2147440/raw/main/remote-update)"
i did this, it say something 1 gb download and install around 6gb and i Y it
so i assume it take atleast an hour so i plug my pc in charger then update it till then i go walk around so i open bluetooth settings from dock panel above and try to discconect bluetooth then i notice my dock is lagged so i shut down it and try again
and now it say
warning: config file /etc/pacman.conf, line 38: directive 'ParallelDownloads' in section 'options' not recognized.
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
error: failed to update chaotic-aur (unable to lock database)
error: failed to synchronize all databases
Better not to touch anything during such massive updates.
Try first to remove the lock with:
sudo rm /var/lib/pacman/db.lck
Then clean the cache:
sudo rm /var/cache/pacman/*
To avoid troubles with partial downloads.
Finally relaunch the snippet above.
Should I yes to all replace
Yes please do.
I think massive is an understatement
This is a pre pacman 6 system. Whoa!
Garuda Jurassic Edition?
End Of OT
I wonder how far you could go back and update a system with that script.
I'll do some more improvements to the update script today to try and support even more legacy systems just for fun
Also this is why I made this Currently rolling out: Introducing Garuda System Maintenance - #18 by TNE
I've always been a great fan of all your scripts, snippets and various tricks, but if you improve it even more you deserve a nomination for best script/tool/hammer/whatnot of 2022.
So much for any distowatch or similar reviews...
Edit: ops, changed a wovel that makes the difference
finally updates done successfully
and i also restart it
but still it went off automatically at 20 % without any notification or warning
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=eb25f8ea-11dc-4da6-a55d-277ba4b0fab7 rw rootflags=subvol=@
Type: Laptop System: HP product: HP Laptop 15q-bu0xx
Mobo: HP model: 8328 v: 23.37 serial: <superuser required>
UEFI-[Legacy]: Insyde v: F.42 date: 08/06/2018
ID-1: BAT1 charge: 8.4 Wh (29.3%) condition: 28.7/41.6 Wh (68.9%)
volts: 15.4 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Charging
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1991 high: 2000 min/max: 400/2000 scaling:
driver: intel_pstate governor: performance cores: 1: 1965 2: 2000 3: 2000
4: 2000 bogomips: 15999
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:2c9b class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-4:2 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 931.51 GiB used: 15.06 GiB (1.6%)
model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A02 scheme: MBR
ID-1: / raw-size: 41.01 GiB size: 41.01 GiB (100.00%)
used: 15.06 GiB (36.7%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 41.01 GiB size: 41.01 GiB (100.00%)
ID-3: /var/log raw-size: 41.01 GiB size: 41.01 GiB (100.00%)
ID-4: /var/tmp raw-size: 41.01 GiB size: 41.01 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C pch: 45.5 C mobo: 27.8 C
Processes: 208 Uptime: 5m wakeups: 1 Memory: 7.68 GiB
used: 2.15 GiB (28.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1251 lib: 302 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-01-27
Last full system update: 2022-02-06
Snapshots: Timeshift (maybe)
