Hey, I'm aref. I'm new to Arch and Garuda. Recently I've installed Garuda KDE Dragonized. But my problem is my internet bandwidth is super slow while it is ultra fast on my Galaxy A12 device. How can I make my internet super fast on Garuda KDE Dragonized?
My PC specs:
Intel Pentium G3250
1TB HDD
DDR3 8GB RAM
Garuda Inxi:
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=182020b1-c063-43bd-bc51-7ba8cdaef1fc rw rootflags=subvol=@
resume=UUID=e438a9d4-1e0c-4c04-ab63-46033c7cd028 loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F2 date: 08/11/2015
Info: model: Intel Pentium G3250 bits: 64 type: MCP arch: Haswell level: v2
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB
desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 800/3200 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 798 2: 798 bogomips: 12771
disabled
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm
built: 2010 ports: active: VGA-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:0402 class-ID: 0300
s-diag: 414mm (16.31")
Monitor-1: VGA-1 model: HP V194 serial: <filter> built: 2018 res: 1366x768
hz: 60 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06") diag: 470mm (18.5")
ratio: 16:9 modes: max: 1366x768 min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics (HSW GT1)
direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 3-1:2 chip-ID: 31b2:5075
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: KTMicro KT USB Audio type: USB
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Local Storage: total: 931.51 GiB used: 63.85 GiB (6.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A8R0 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
used: 63.85 GiB (6.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-4: /var/log raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 198 Uptime: 1h 35m wakeups: 0 Memory: 7.66 GiB
used: 3.82 GiB (49.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1343
libs: 360 tools: octopi,pamac,paru,yay Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-18
Last full system update: 2022-11-20
