Hello.
I've been trying to get the microphone of my bluetooth headphones (Soundcore Life Q30) working and, as expected, it only works on HSP/HFP, the problem is that the audio quality is really bad, changing the codec to mSBC should fix it, but instead i get a loud buzzing noise that hurts my ears, from what i could gather, this is a problem with the kernel on 5.16 and downgrading to 5.15 should fix it.
Kernel: 5.16.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=b7622284-c5d1-4dab-99e5-59404e2a3b09 rw rootflags=subvol=@
resume=UUID=ddff92b5-7dbe-4d06-b7f5-347468563158 loglevel=3
Type: Laptop System: Acer product: Aspire A515-44 v: V1.02
serial:
Mobo: RO model: Calla_RN v: V1.02 serial:
UEFI: INSYDE v: 1.02 date: 03/23/2020
ID-1: BAT1 charge: 36.1 Wh (100.0%) condition: 36.1/47.8 Wh (75.5%)
volts: 12.3 min: 11.2 model: LGC AP18C8K type: Li-ion serial:
status: Full
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 6 smt: cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2240 high: 2872 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2547 2: 2248
3: 2872 4: 1546 5: 1763 6: 2469 bogomips: 28447
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) type: USB
driver: hid-generic,usbhid bus-ID: 3-2:2 chip-ID: 0c45:8006 class-ID: 0301
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 04f2:b64f class-ID: 0e02 serial:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 950x285mm (37.4x11.2")
s-diag: 992mm (39")
Monitor-1: HDMI-A-0 mapped: HDMI-A-1 pos: right model: HP LA2205
serial: built: 2012 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 473x296mm (18.6x11.7") diag: 558mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
Monitor-2: eDP pos: primary,left res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.16-zen1-1-zen LLVM 13.0.1)
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp4s0 state: down mac:
IF-ID-1: anbox0 state: down mac:
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-3:3
chip-ID: 04ca:3016 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address:
Local Storage: total: 1.82 TiB used: 1.18 TiB (65.0%)
model: WD Green SN350 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 33006000 temp: 24.9 C scheme: GPT
model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial:
rev: 1A02 scheme: GPT
ID-1: / raw-size: 914.64 GiB size: 914.64 GiB (100.00%)
used: 223.42 GiB (24.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 914.64 GiB size: 914.64 GiB (100.00%)
ID-4: /var/log raw-size: 914.64 GiB size: 914.64 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.64 GiB size: 914.64 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.57 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.06 GiB used: 1.91 GiB (12.7%)
System Temperatures: cpu: 61.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Processes: 364 Uptime: 8h 4m wakeups: 1 Memory: 15.07 GiB
used: 11.64 GiB (77.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2006 lib: 561 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-21
Last full system update: 2022-03-23
