i
root=UUID=3c7f7d5e-e8b1-438a-8e71-ab7fb26810b3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.0 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop System: Micro-Star product: MS-7C56 v: 2.0
Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
Megatrends LLC. v: A.F0 date: 10/11/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540e
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3678 min/max: 561/4654 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3678 2: 3678 3: 3678
4: 3678 5: 3678 6: 3678 7: 3678 8: 3678 9: 3678 10: 3678 11: 3678 12: 3678
bogomips: 88800
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Tul / PowerColor driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
DP-3, HDMI-A-1, Writeback-1 bus-ID: 2d:00.0 chip-ID: 1002:73df
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: Dell G2724D serial: <filter> built: 2024 res:
mode: 2560x1440 hz: 165 scale: 114% (1.15) to: 2226x1252 dpi: 109 gamma: 1.2
size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
navi22 LLVM 20.1.6 DRM 3.63 6.15.3-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.4.313 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 25.1.4-arch1.1
device-ID: 1002:73df surfaces: N/A device: 1 type: cpu name: llvmpipe
bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api tools: N/A
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 53.28 TiB used: 39.85 TiB (74.8%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 1.86 TiB block-size: physical: 512 B
fw-rev: VC2S038E temp: 45.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR311 temp: 39.9 C
scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWE150 size: 4.55 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: KLEVV model: NEO N610 SSD 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 7D scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000DM004-2U9188
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: Backup+ Hub BK
size: 9.1 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.1
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: D781
ID-7: /dev/sde maj-min: 8:64 vendor: Utania model: OOS12000G
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> scheme: GPT
ID-8: /dev/sdf maj-min: 8:80 vendor: Hitachi model: HUH721010ALE601
size: 9.1 TiB block-size: physical: 4096 B logical: 4096 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 0209 scheme: GPT
ID-9: /dev/sdg maj-min: 8:96 vendor: Seagate model: Backup+ Hub BK
fw-rev: D781 scheme: GPT
ID-1: / raw-size: 212.25 GiB size: 212.25 GiB (100.00%)
used: 19.87 GiB (9.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
used: 297.98 GiB (4.0%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-4: /var/log raw-size: 212.25 GiB size: 212.25 GiB (100.00%)
ID-5: /var/tmp raw-size: 212.25 GiB size: 212.25 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.72 GiB used: 1.27 GiB (2.0%)
System Temperatures: cpu: 57.6 C mobo: N/A gpu: amdgpu temp: 60.0 C
mem: 52.0 C
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 6.56 GiB (10.5%)
Processes: 437 Power: uptime: 1h 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.07 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1677 libs: 505 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date: 2025-06-17
Last full system update: 2025-06-24 ↻
In the last couple of days, I have lost system sounds. VLC is muted. Everything looks okay in Settings, but I have no sound. Is there something I didn’t see using garuda-inxi?
What is the output of
systemctl --user status pipewire*
Should be unrelated (if trusting patchnotes), but you’re 6 BIOS releases behind: https://www.msi.com/Motherboard/B550-A-PRO/support
Updated the BIOS. Had to disable Secure Boot. Still no sound.
hi
can you try this in the Terminal.
garuda-update remote reset-audio
[sudo] password for oldrocker99:
garuda 53.9 KiB 8.82 KiB/s 00:06 [------------------------------------] 100%
core 116.5 KiB 303 KiB/s 00:00 [------------------------------------] 100%
extra 7.8 MiB 1302 KiB/s 00:06 [------------------------------------] 100%
multilib 134.9 KiB 314 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 630.4 KiB 99.4 KiB/s 00:06 [------------------------------------] 100%
warning: garuda-update-4.10.2-1 is up to date -- reinstalling
resolving dependencies...
Package (1) Old Version New Version Net Change
garuda/garuda-update 4.10.2-1 4.10.2-1 0.00 MiB
Total Installed Size: 0.03 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [------------------------------------] 100%
(1/1) checking package integrity [------------------------------------] 100%
(1/1) loading package files [------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------] 100%
(1/1) checking available disk space [------------------------------------] 100%
snapper snapshots skipped
(1/1) reinstalling garuda-update [------------------------------------] 100%
(1/8) Arming ConditionNeedsUpdate...
(2/8) Checking for package with missing dependencies...
(3/8) Refreshing PackageKit...
(4/8) Foreign/AUR package notification
asoundconf 1:1.2-9
caja-rename 25.6.1-1
kitemmodels5 5.116.0-1
(5/8) Orphaned package notification...
adobe-source-code-pro-fonts 2.042u+1.062i+1.026vf-2
cmake-extras-git 1.8.r2.gd2b8aeb-1
fish-autopair 1.0.4-2
intltool 0.51.0-6
python-build 1.2.2-3
python-installer 0.7.0-10
vulkan-headers 1:1.4.313.0-1
(6/8) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/hosts.pacnew
Please check and merge
(7/8) Performing snapper post snapshots for the following configurations...
(8/8) Syncing all file systems...
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
spawn pacman -Su
warning: kwin-effect-rounded-corners-git: local (0.7.2.r48.g284647c-1.1) is newer than chaotic-aur (0.7.2.r48.g284647c-1)
warning: snapper-tools: local (1.3.1-1.6) is newer than chaotic-aur (1.3.1-1)
warning: dependency cycle detected:
warning: xdg-desktop-portal-kde will be installed before its plasma-workspace dependency
Package (62) Old Version New Version Net Change Download Size
core/amd-ucode 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 0.09 MiB
extra/aurorae 6.4.0-1 6.4.1-1 0.00 MiB 0.10 MiB
extra/bluedevil 1:6.4.0-1 1:6.4.1-1 0.00 MiB 0.57 MiB
extra/breeze 6.4.0-1 6.4.1-1 0.00 MiB 40.02 MiB
extra/discover 6.4.0-1 6.4.1-1 0.00 MiB 1.44 MiB
chaotic-aur/google-chrome 137.0.7151.119-1 138.0.7204.49-1 -1.71 MiB 154.18 MiB
extra/kactivitymanagerd 6.4.0-1 6.4.1-1 0.00 MiB 0.20 MiB
extra/kde-cli-tools 6.4.0-1 6.4.1-1 0.00 MiB 0.88 MiB
extra/kde-gtk-config 6.4.0-1 6.4.1-1 0.00 MiB 0.09 MiB
extra/kdecoration 6.4.0-1 6.4.1-1 0.00 MiB 0.09 MiB
extra/kdeplasma-addons 6.4.0-1 6.4.1-1 0.01 MiB 1.28 MiB
extra/kglobalacceld 6.4.0-1 6.4.1-1 0.00 MiB 0.10 MiB
extra/kinfocenter 6.4.0-1 6.4.1-1 0.00 MiB 0.91 MiB
extra/kmenuedit 6.4.0-1 6.4.1-1 0.00 MiB 1.01 MiB
extra/kpipewire 6.4.0-1 6.4.1-1 0.00 MiB 0.14 MiB
extra/kscreen 6.4.0-1 6.4.1-1 0.01 MiB 30.46 MiB
extra/kscreenlocker 6.4.0-1 6.4.1-1 0.00 MiB 0.25 MiB
extra/ksshaskpass 6.4.0-1 6.4.1-1 0.00 MiB 0.03 MiB
extra/ksystemstats 6.4.0-1 6.4.1-1 0.00 MiB 0.28 MiB
extra/kwallet-pam 6.4.0-1 6.4.1-1 0.00 MiB 0.01 MiB
extra/kwayland 6.4.0-1 6.4.1-1 0.00 MiB 1.23 MiB
extra/kwayland-integration 6.4.0-1 6.4.1-1 0.00 MiB 0.04 MiB
extra/kwin 6.4.0-1 6.4.1-1 0.01 MiB 10.06 MiB
chaotic-aur/kwin-effects-forceblur 1.4.0-3 1.4.0-3.1 0.00 MiB 0.09 MiB
extra/layer-shell-qt 6.4.0-1 6.4.1-1 0.00 MiB 0.03 MiB
extra/libkscreen 6.4.0-1 6.4.1-1 0.00 MiB 0.43 MiB
extra/libksysguard 6.4.0-1 6.4.1-1 0.01 MiB 0.68 MiB
extra/libplasma 6.4.0-1 6.4.1-1 0.00 MiB 2.74 MiB
extra/libssh 0.11.1-1 0.11.2-1 0.00 MiB 0.21 MiB
core/linux-firmware 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 0.00 MiB
core/linux-firmware-amdgpu 20250613.12fe085f-6 20250613.12fe085f-9 0.21 MiB 24.33 MiB
core/linux-firmware-atheros 20250613.12fe085f-6 20250613.12fe085f-9 -0.06 MiB 41.54 MiB
core/linux-firmware-broadcom 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 12.89 MiB
core/linux-firmware-cirrus 20250613.12fe085f-9 1.61 MiB 1.61 MiB
core/linux-firmware-intel 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 104.48 MiB
core/linux-firmware-mediatek 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 21.97 MiB
core/linux-firmware-nvidia 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 98.83 MiB
core/linux-firmware-other 20250613.12fe085f-6 20250613.12fe085f-9 -0.23 MiB 24.83 MiB
core/linux-firmware-radeon 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 2.31 MiB
core/linux-firmware-realtek 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 5.32 MiB
core/linux-firmware-whence 20250613.12fe085f-6 20250613.12fe085f-9 0.00 MiB 0.04 MiB
extra/milou 6.4.0-1 6.4.1-1 0.00 MiB 0.08 MiB
extra/ocean-sound-theme 6.4.0-1 6.4.1-1 0.00 MiB 1.92 MiB
extra/plasma-activities 6.4.0-1 6.4.1-1 0.00 MiB 0.28 MiB
extra/plasma-activities-stats 6.4.0-1 6.4.1-1 0.00 MiB 0.28 MiB
extra/plasma-browser-integration 6.4.0-1 6.4.1-1 0.00 MiB 0.17 MiB
extra/plasma-desktop 6.4.0-1 6.4.1-1 0.03 MiB 16.92 MiB
extra/plasma-firewall 6.4.0-1 6.4.1-1 0.00 MiB 0.48 MiB
extra/plasma-integration 6.4.0-1 6.4.1-1 0.00 MiB 0.14 MiB
extra/plasma-nm 6.4.0-1 6.4.1-1 0.00 MiB 1.81 MiB
extra/plasma-pa 6.4.0-1 6.4.1-1 0.00 MiB 0.40 MiB
extra/plasma-systemmonitor 6.4.0-1 6.4.1-1 0.00 MiB 0.44 MiB
extra/plasma-thunderbolt 6.4.0-1 6.4.1-1 0.00 MiB 0.13 MiB
extra/plasma-workspace 6.4.0-5 6.4.1-1 -0.01 MiB 21.77 MiB
extra/plasma5support 6.4.0-1 6.4.1-1 0.00 MiB 0.69 MiB
extra/polkit-kde-agent 6.4.0-1 6.4.1-1 0.00 MiB 0.07 MiB
extra/powerdevil 6.4.0-1 6.4.1-1 0.00 MiB 1.37 MiB
extra/qqc2-breeze-style 6.4.0-1 6.4.1-1 0.00 MiB 0.36 MiB
extra/sddm-kcm 6.4.0-1 6.4.1-1 0.00 MiB 0.15 MiB
extra/spectacle 1:6.4.0-1 1:6.4.1-1 0.02 MiB 2.07 MiB
extra/systemsettings 6.4.0-1 6.4.1-1 0.00 MiB 0.34 MiB
extra/xdg-desktop-portal-kde 6.4.0-1 6.4.1-1 0.00 MiB 0.48 MiB
Total Download Size: 636.14 MiB
Total Installed Size: 1025.66 MiB
Net Upgrade Size: -0.09 MiB
:: Retrieving packages...
breeze-6.4.1-1-x86_64 40.0 MiB 2.31 MiB/s 00:17 [------------------------------------] 100%
linux-firmware-atheros-20250613.... 41.5 MiB 1390 KiB/s 00:31 [------------------------------------] 100%
kscreen-6.4.1-1-x86_64 30.5 MiB 2.09 MiB/s 00:15 [------------------------------------] 100%
linux-firmware-nvidia-20250613.1... 98.8 MiB 2.76 MiB/s 00:36 [------------------------------------] 100%
linux-firmware-other-20250613.12... 24.8 MiB 1750 KiB/s 00:15 [------------------------------------] 100%
linux-firmware-amdgpu-20250613.1... 24.3 MiB 1732 KiB/s 00:14 [------------------------------------] 100%
linux-firmware-intel-20250613.12... 104.5 MiB 2.23 MiB/s 00:47 [------------------------------------] 100%
linux-firmware-mediatek-20250613... 22.0 MiB 1853 KiB/s 00:12 [------------------------------------] 100%
linux-firmware-broadcom-20250613... 12.9 MiB 1739 KiB/s 00:08 [------------------------------------] 100%
kwin-6.4.1-1-x86_64 10.1 MiB 1570 KiB/s 00:07 [------------------------------------] 100%
plasma-desktop-6.4.1-1-x86_64 16.9 MiB 1758 KiB/s 00:10 [------------------------------------] 100%
libplasma-6.4.1-1-x86_64 2.7 MiB 1426 KiB/s 00:02 [------------------------------------] 100%
google-chrome-138.0.7204.49-1-x86_64 154.2 MiB 2.69 MiB/s 00:57 [------------------------------------] 100%
plasma-workspace-6.4.1-1-x86_64 21.8 MiB 1770 KiB/s 00:13 [------------------------------------] 100%
linux-firmware-realtek-20250613.... 5.3 MiB 1587 KiB/s 00:03 [------------------------------------] 100%
linux-firmware-radeon-20250613.1... 2.3 MiB 1527 KiB/s 00:02 [------------------------------------] 100%
spectacle-1:6.4.1-1-x86_64 2.1 MiB 1544 KiB/s 00:01 [------------------------------------] 100%
ocean-sound-theme-6.4.1-1-any 1967.0 KiB 2.07 MiB/s 00:01 [------------------------------------] 100%
plasma-nm-6.4.1-1-x86_64 1857.1 KiB 2.87 MiB/s 00:01 [------------------------------------] 100%
linux-firmware-cirrus-20250613.1... 1653.3 KiB 2.73 MiB/s 00:01 [------------------------------------] 100%
discover-6.4.1-1-x86_64 1478.6 KiB 2.57 MiB/s 00:01 [------------------------------------] 100%
powerdevil-6.4.1-1-x86_64 1401.0 KiB 2.31 MiB/s 00:01 [------------------------------------] 100%
kdeplasma-addons-6.4.1-1-x86_64 1306.9 KiB 2.83 MiB/s 00:00 [------------------------------------] 100%
kwayland-6.4.1-1-x86_64 1261.8 KiB 3.27 MiB/s 00:00 [------------------------------------] 100%
kmenuedit-6.4.1-1-x86_64 1039.1 KiB 2.41 MiB/s 00:00 [------------------------------------] 100%
kinfocenter-6.4.1-1-x86_64 929.2 KiB 2.33 MiB/s 00:00 [------------------------------------] 100%
plasma5support-6.4.1-1-x86_64 705.6 KiB 2.34 MiB/s 00:00 [------------------------------------] 100%
kde-cli-tools-6.4.1-1-x86_64 901.7 KiB 2.55 MiB/s 00:00 [------------------------------------] 100%
libksysguard-6.4.1-1-x86_64 695.0 KiB 3.52 MiB/s 00:00 [------------------------------------] 100%
bluedevil-1:6.4.1-1-x86_64 581.7 KiB 3.38 MiB/s 00:00 [------------------------------------] 100%
plasma-firewall-6.4.1-1-x86_64 496.3 KiB 2.65 MiB/s 00:00 [------------------------------------] 100%
xdg-desktop-portal-kde-6.4.1-1-x... 492.7 KiB 2.70 MiB/s 00:00 [------------------------------------] 100%
plasma-systemmonitor-6.4.1-1-x86_64 450.5 KiB 2.33 MiB/s 00:00 [------------------------------------] 100%
libkscreen-6.4.1-1-x86_64 437.7 KiB 2.62 MiB/s 00:00 [------------------------------------] 100%
plasma-pa-6.4.1-1-x86_64 408.4 KiB 3.09 MiB/s 00:00 [------------------------------------] 100%
qqc2-breeze-style-6.4.1-1-x86_64 365.2 KiB 2.70 MiB/s 00:00 [------------------------------------] 100%
systemsettings-6.4.1-1-x86_64 352.6 KiB 2.61 MiB/s 00:00 [------------------------------------] 100%
plasma-activities-6.4.1-1-x86_64 289.4 KiB 2.00 MiB/s 00:00 [------------------------------------] 100%
plasma-activities-stats-6.4.1-1-... 283.3 KiB 2.32 MiB/s 00:00 [------------------------------------] 100%
ksystemstats-6.4.1-1-x86_64 283.0 KiB 2.19 MiB/s 00:00 [------------------------------------] 100%
kscreenlocker-6.4.1-1-x86_64 258.1 KiB 2.65 MiB/s 00:00 [------------------------------------] 100%
libssh-0.11.2-1-x86_64 218.0 KiB 2018 KiB/s 00:00 [------------------------------------] 100%
kactivitymanagerd-6.4.1-1-x86_64 203.1 KiB 1991 KiB/s 00:00 [------------------------------------] 100%
plasma-browser-integration-6.4.1... 177.4 KiB 1674 KiB/s 00:00 [------------------------------------] 100%
sddm-kcm-6.4.1-1-x86_64 152.5 KiB 1540 KiB/s 00:00 [------------------------------------] 100%
plasma-integration-6.4.1-1-x86_64 144.3 KiB 1622 KiB/s 00:00 [------------------------------------] 100%
kpipewire-6.4.1-1-x86_64 141.8 KiB 1289 KiB/s 00:00 [------------------------------------] 100%
plasma-thunderbolt-6.4.1-1-x86_64 137.3 KiB 1596 KiB/s 00:00 [------------------------------------] 100%
kglobalacceld-6.4.1-1-x86_64 106.9 KiB 1018 KiB/s 00:00 [------------------------------------] 100%
aurorae-6.4.1-1-x86_64 105.8 KiB 928 KiB/s 00:00 [------------------------------------] 100%
amd-ucode-20250613.12fe085f-9-any 91.9 KiB 1010 KiB/s 00:00 [------------------------------------] 100%
kdecoration-6.4.1-1-x86_64 90.8 KiB 1009 KiB/s 00:00 [------------------------------------] 100%
kde-gtk-config-6.4.1-1-x86_64 87.8 KiB 1141 KiB/s 00:00 [------------------------------------] 100%
milou-6.4.1-1-x86_64 79.0 KiB 898 KiB/s 00:00 [------------------------------------] 100%
linux-firmware-whence-20250613.1... 39.8 KiB 623 KiB/s 00:00 [------------------------------------] 100%
polkit-kde-agent-6.4.1-1-x86_64 72.5 KiB 642 KiB/s 00:00 [------------------------------------] 100%
kwayland-integration-6.4.1-1-x86_64 38.6 KiB 354 KiB/s 00:00 [------------------------------------] 100%
layer-shell-qt-6.4.1-1-x86_64 35.5 KiB 444 KiB/s 00:00 [------------------------------------] 100%
ksshaskpass-6.4.1-1-x86_64 33.5 KiB 356 KiB/s 00:00 [------------------------------------] 100%
kwallet-pam-6.4.1-1-x86_64 12.9 KiB 159 KiB/s 00:00 [------------------------------------] 100%
linux-firmware-20250613.12fe085f... 2.4 KiB 20.8 KiB/s 00:00 [------------------------------------] 100%
kwin-effects-forceblur-1.4.0-3.1... 92.8 KiB 149 KiB/s 00:01 [------------------------------------] 100%
Total (62/62) 636.1 MiB 10.4 MiB/s 01:01 [------------------------------------] 100%
(62/62) checking keys in keyring [------------------------------------] 100%
(62/62) checking package integrity [------------------------------------] 100%
(62/62) loading package files [------------------------------------] 100%
(62/62) checking for file conflicts [------------------------------------] 100%
(62/62) checking available disk space [------------------------------------] 100%
==> root: 29
( 1/62) upgrading amd-ucode [------------------------------------] 100%
( 2/62) upgrading kdecoration [------------------------------------] 100%
( 3/62) upgrading aurorae [------------------------------------] 100%
( 4/62) upgrading plasma-activities [------------------------------------] 100%
( 5/62) upgrading libplasma [------------------------------------] 100%
( 6/62) upgrading bluedevil [------------------------------------] 100%
( 7/62) upgrading breeze [------------------------------------] 100%
( 8/62) upgrading libssh [------------------------------------] 100%
( 9/62) upgrading discover [------------------------------------] 100%
(10/62) upgrading google-chrome [------------------------------------] 100%
(11/62) upgrading kactivitymanagerd [------------------------------------] 100%
(12/62) upgrading kde-cli-tools [------------------------------------] 100%
(13/62) upgrading kde-gtk-config [------------------------------------] 100%
(14/62) upgrading kglobalacceld [------------------------------------] 100%
(15/62) upgrading layer-shell-qt [------------------------------------] 100%
(16/62) upgrading libkscreen [------------------------------------] 100%
(17/62) upgrading kscreenlocker [------------------------------------] 100%
(18/62) upgrading kwayland [------------------------------------] 100%
(19/62) upgrading kwin [------------------------------------] 100%
The KWin X window manager has been split to a separate kwin-x11 package.
(20/62) upgrading kpipewire [------------------------------------] 100%
(21/62) upgrading libksysguard [------------------------------------] 100%
(22/62) upgrading ksystemstats [------------------------------------] 100%
(23/62) upgrading milou [------------------------------------] 100%
(24/62) upgrading ocean-sound-theme [------------------------------------] 100%
(25/62) upgrading plasma-activities-stats [------------------------------------] 100%
(26/62) upgrading plasma5support [------------------------------------] 100%
(27/62) upgrading qqc2-breeze-style [------------------------------------] 100%
(28/62) upgrading xdg-desktop-portal-kde [------------------------------------] 100%
(29/62) upgrading plasma-integration [------------------------------------] 100%
(30/62) upgrading plasma-workspace [------------------------------------] 100%
(31/62) upgrading kdeplasma-addons [------------------------------------] 100%
(32/62) upgrading systemsettings [------------------------------------] 100%
(33/62) upgrading kinfocenter [------------------------------------] 100%
(34/62) upgrading kmenuedit [------------------------------------] 100%
(35/62) upgrading kscreen [------------------------------------] 100%
(36/62) upgrading ksshaskpass [------------------------------------] 100%
(37/62) upgrading kwallet-pam [------------------------------------] 100%
(38/62) upgrading kwayland-integration [------------------------------------] 100%
(39/62) upgrading kwin-effects-forceblur [------------------------------------] 100%
==> WARNING: To use this effect disable the default Blur effect and any other forks of the blur effect as well(such as the one provided by LightlyShaders). Then enable the Force Blur effect. You can do this under Desktop Effects in System Settings
(40/62) upgrading linux-firmware-whence [------------------------------------] 100%
(41/62) upgrading linux-firmware-amdgpu [------------------------------------] 100%
(42/62) upgrading linux-firmware-atheros [------------------------------------] 100%
(43/62) upgrading linux-firmware-broadcom [------------------------------------] 100%
(44/62) installing linux-firmware-cirrus [------------------------------------] 100%
(45/62) upgrading linux-firmware-intel [------------------------------------] 100%
(46/62) upgrading linux-firmware-mediatek [------------------------------------] 100%
(47/62) upgrading linux-firmware-nvidia [------------------------------------] 100%
(48/62) upgrading linux-firmware-other [------------------------------------] 100%
(49/62) upgrading linux-firmware-radeon [------------------------------------] 100%
(50/62) upgrading linux-firmware-realtek [------------------------------------] 100%
(51/62) upgrading linux-firmware [------------------------------------] 100%
(52/62) upgrading plasma-browser-integration [------------------------------------] 100%
(53/62) upgrading polkit-kde-agent [------------------------------------] 100%
(54/62) upgrading powerdevil [------------------------------------] 100%
(55/62) upgrading plasma-desktop [------------------------------------] 100%
(56/62) upgrading plasma-firewall [------------------------------------] 100%
(57/62) upgrading plasma-nm [------------------------------------] 100%
(58/62) upgrading plasma-pa [------------------------------------] 100%
(59/62) upgrading plasma-systemmonitor [------------------------------------] 100%
(60/62) upgrading plasma-thunderbolt [------------------------------------] 100%
(61/62) upgrading sddm-kcm [------------------------------------] 100%
(62/62) upgrading spectacle [------------------------------------] 100%
( 1/13) Reloading user manager configuration...
( 2/13) Arming ConditionNeedsUpdate...
( 3/13) Updating the MIME type database...
( 4/13) Checking for package with missing dependencies...
( 5/13) Refreshing PackageKit...
( 6/13) Foreign/AUR package notification
asoundconf 1:1.2-9
( 7/13) Orphaned package notification...
intltool 0.51.0-6
( 8/13) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/hosts.pacnew
( 9/13) Reloading system bus configuration...
(10/13) Updating icon theme caches...
(11/13) Updating the desktop file MIME type cache...
(12/13) Performing snapper post snapshots for the following configurations...
==> root: 30
(13/13) Syncing all file systems...
System updated! 🐧
pipewire
pipewire-pulse
wireplumber
warning: wireplumber-0.5.10-1 is up to date -- skipping
warning: pipewire-support-1-16 is up to date -- skipping
there is nothing to do
Failed to disable unit: Unit pulseaudio.service does not exist
╭─oldrocker99@oldrockjer99 in ~ as 🧙 took 2m15s
[🔴] × yay -S pulseaudio
:: pulseaudio-17.0+r43+g3e2bb8a1e-1 and pipewire-pulse-1:1.4.5-1 are in conflict. Remove pipewire-pulse? [y/N]y
:: removing pipewire-pulse breaks dependency 'pipewire-pulse' required by pipewire-support
:: removing pipewire-pulse breaks dependency 'pipewire-pulse' required by pulse-native-provider
fish: No matches for wildcard 'pipewire*'. See `help wildcards-globbing`.
Have you had any audio issues in the past that forced you to change to any abnormal configuration or use PulseAudio rather than Pipewire?
Oops it’s fish, sorry I’m used to Bash. The correct version for that requires a quote for the glob:
systemctl --user status "pipewire*"
i got the same error message ive think maybe they swapped it to a user service not a systemd service.
Did you run sound on the Monitor or external Speaker?
I would try to disconnect the power cord from the PC press few times the power button wait few minutes and start the Pc again. (called cold boot)
My sound is working even with this error message. May a AMD Firmware issue.
see here this topic:
All looks good. Do you have audio working now too?
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
Active: active (running) since Wed 2025-06-25 11:07:14 EDT; 2h 32min ago
Invocation: 1db6437b8ca5423d8786f59e0e21e189
TriggeredBy: ● pipewire.socket
Main PID: 3947 (pipewire)
Tasks: 3 (limit: 76899)
Memory: 15.1M (peak: 17.7M)
CPU: 1.353s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─3947 /usr/bin/pipewire
Notice: journal has been rotated since unit was started, output may be incomplete.
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
Active: active (running) since Wed 2025-06-25 11:07:23 EDT; 2h 32min ago
Invocation: 64866c15e0c744279d05ae97cc79fb6f
TriggeredBy: ● pipewire-pulse.socket
Main PID: 5324 (pipewire-pulse)
Tasks: 2 (limit: 76899)
Memory: 12.2M (peak: 15.9M)
CPU: 1.828s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─5324 /usr/bin/pipewire-pulse
i run sound on external speakers.
I have no idea if this will help you at all, but I had a similar issue, and it happens occasionally that my audio just stops working. Since I don’t have any custom configs for pipewire, what I do is delete all the files inside ~/.local/state/wireplumber/ then issue this command in the terminal: systemctl --user restart pipewire pipewire-pulse wireplumber and then it just works again. I found this solution from here: https://www.reddit.com/r/archlinux/comments/1e0tp14/comment/lcv5of7/
Hope this helps!
Anyone here can explain why the above solution works? Like, what would cause the audio to stop working to begin with that this solves it? Forgive my ignorance, as I’m sure there could be a variety of causes and this seems kind of like an overkill solution, but all I know is that it works.
systemctl --user restart pipewire pipwire-pulse wireplumber
I had to rename pipwire-pulse to pipewire-pulse, and it WORKED! Thank you so much!
You’re missing the pipewire socket, but have the services… How could that have happened?!
pacman -F pipewire.socket
Confirms it is indeed provided by extra/pipewire… so you should most certainly have it, and it should have shown in the status.
Please reinstall pipewire and rerun status command, it should then show the socket as intended.
Active: active (running) since Wed 2025-06-25 17:13:56 EDT; 4h 11min ago
Invocation: 00fa56d193c7464fa36fdd96c333dace
Main PID: 4908 (pipewire-pulse)
Memory: 16.9M (peak: 27.5M)
CPU: 6.735s
└─4908 /usr/bin/pipewire-pulse
Active: active (running) since Wed 2025-06-25 17:13:48 EDT; 4h 11min ago
Invocation: 22db6c592a8645968b797d8ca9feb851
Main PID: 3632 (pipewire)
Memory: 9M (peak: 13.6M)
CPU: 4.008s
└─3632 /usr/bin/pipewire
● pipewire.socket - PipeWire Multimedia System Sockets
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; preset: enabled)
Active: active (running) since Wed 2025-06-25 17:13:42 EDT; 4h 11min ago
Invocation: d0b7a941e6fe417fada496cf49ead868
Triggers: ● pipewire.service
Listen: /run/user/1000/pipewire-0 (Stream)
/run/user/1000/pipewire-0-manager (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
● pipewire-pulse.socket - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.socket; enabled; preset: enabled)
Invocation: 3da59c017e304075aecd5367d2e2f2e9
Triggers: ● pipewire-pulse.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire-pulse.socket
This was after I reinstalled pipewire.
Excellent it shows and is enabled once more, I can call this success now.
The socket should have handled it [re]starting automatically, but it didn’t exist.
sockets.target
A special target unit that sets up all socket units (see systemd.socket for details) that shall be active after boot. Services that can be socket-activated shall add Wants=dependencies to this unit for their socket unit during installation. This is best configured via a WantedBy=sockets.target in the socket unit’s [Install] section.
system
Closed
28 June 2025 02:54
17
