Hello, fellow Linux users. I have recently started using Garuda Linux about a month ago on my laptop (Dell G5) and usually connect my external monitor to it to have a dual screen setup. The problem is many times after I wake up my laptop (from opening the lid), my laptop display is working correctly but my external display is unrecognized. I usually have to unplug and plug the HDMI connector, only for nothing to happen. It’s usually the 2nd time I reconnect my HDMI connector that it works, but this logs me out of the desktop session (using XFCE btw). I am forced to re-login and applications I had open will close. I’ve been using strictly Linux for 2 years now so I’m still learning things. Thank you for your help!
Kernel: 6.6.28-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=55f9c52f-7e98-4d28-8d24-defd29bb53f3 rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: Dell product: G3 3579 v: N/A
Mobo: Dell model: 05K0D2 v: A00 serial: <superuser required> part-nu: 086F
uuid: <superuser required> UEFI: Dell v: 1.21.0 date: 04/14/2022
ID-1: BAT0 charge: 9.8 Wh (22.1%) condition: 44.3/56.0 Wh (79.2%)
volts: 15.0 min: 15.2 model: LGC-LGC3.553 DELL 81PF3 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 870 high: 991 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 991 2: 973 3: 800 4: 800
5: 900 6: 800 7: 900 8: 800 bogomips: 36812
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: none bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
chip-ID: 1bcf:28c1 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1273 s-dpi: 96 s-size: 1016x337mm (40.00x13.27")
s-diag: 1070mm (42.14")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: top-right
model: Sceptre F24 serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 520x320mm (20.47x12.6") diag: 611mm (24.1")
ratio: 16:10 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: primary,bottom-l model: LG Display 0x053f
built: 2016 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 driver: nvidia v: 550.67
device-ID: 10de:1c8d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
API: ALSA v: k6.6.28-1-lts status: kernel-api tools: N/A
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 35.45 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM3 scheme: GPT
used: 35.44 GiB (3.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C pch: 47.0 C mobo: N/A
Memory: total: 8 GiB available: 7.49 GiB used: 2.71 GiB (36.2%)
Processes: 273 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.95 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1525 libs: 462 tools: paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: alacritty inxi: 3.3.34
System install date: 2024-03-18
Last full system update: 2024-04-19
