This problem is not Garuda, it seems to be linux over all problem.
When i scroll in either browsers or other areas in the desktop that has scroll, it does not start scroll right away, but it takes many bunch of scroll before something happens, then it scrolls alright until i paus a bit and have to restart scrolling.
I tried to solve it my self in my previous installation with cinnamon and plasma and xfce (other dists), same problem exists in them.
With all googling, it seems its something because logitech usb wireless.
At one point middle of the night, i had sort of solver it some how, but then the back/forth button stopped working.
Tried solaar that was in debian stable, The scroll wheel resolution sort of works, but then the scrolling becomes painfully slow.
Tried to install gpointing-device-settings but it fails
=> Making package: gpointing-device-settings 1.5.1-5 (tor 19 dec 2024 10:43:44)
==> Retrieving sources…
→ Downloading gpointing-device-settings-1.5.1.tar.gz…
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 2 0 2 0 0 4 0 --:–:-- --:–:-- --:–:-- 5
0 0 0 0 0 0 0 0 --:–:-- 0:00:01 --:–:-- 0
curl: (60) SSL certificate problem: certificate has expired
More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the webpage mentioned above.
==> ERROR: Failure while downloading http://sourceforge.jp/frs/redir.php?m=iij&f=/gsynaptics/45812/gpointing-device-settings-1.5.1.tar.gz
Aborting…
error: failed to download sources for ‘gpointing-device-settings-1.5.1-5’:
error: packages failed to build: gpointing-device-settings-1.5.1-5
exit status 1
Press ENTER to return to pacseek
Any suggestions how to make this work (better)?
Currently i scroll slow and back/forth button works, but really slow scroll.
Its an Logitech MX Master 2S on a unify dongle.
In a previous installation i tried both X11 and wayland, same scrolling problem.
