When I click on it and enter password nothing happens
Please always provide your garuda-inxi, as required by the template.
I have 2 computers with Garuda MATE on one and XFCE on the other and I noticed this
a few days ago. I noticed that if you try to launch the Login Window tool from a terminal
with the command 'pkexec lightdm-settings', you get this error,
Settings schema 'x.dm.slick-greeter' does not contain a key named 'cursor-theme-size'.
What solved this problem for me on both machines was editing the /etc/lightdm/slick-greeter.conf
file. Under the line cursor-theme-name=Adwaita (or whatever theme you have) I added a new line,
cursor-theme-size=16
and saved the file.
Hope this helps...
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=c3b5a276-2ff5-48eb-b3b9-8882ae70f336 rw [email protected]
resume=UUID=6795e62a-144b-4672-9381-98765df0dba7 loglevel=3 ibt=off
Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: MM-Vision product: Computer v: N/A
Mobo: ASUSTeK model: PRIME B360M-C v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2416
date: 05/23/2019
Info: model: Intel Core i7-9700 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF4
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 3000 min/max: 800/4700 scaling: driver: intel_pstate
governor: performance cores: 1: 3000 2: 3000 3: 3000 4: 3000 5: 3000 6: 3000
7: 3000 8: 3000 bogomips: 48000
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e98 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: marco v: 1.26.1 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: DP-3 model: ASUS VP248 serial: <filter> built: 2019
res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 4.57 TiB used: 99.14 GiB (2.1%)
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 37.9 C scheme: GPT
model: WD40EZRZ-22GXCB0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 884.65 GiB size: 884.65 GiB (100.00%)
used: 99.13 GiB (11.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 884.65 GiB size: 884.65 GiB (100.00%)
ID-4: /var/log raw-size: 884.65 GiB size: 884.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 884.65 GiB size: 884.65 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.66 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 68.92 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 285 Uptime: 2h 42m wakeups: 0 Memory: 62.66 GiB
used: 5.49 GiB (8.8%) Init: systemd v: 252 default: graphical
pkgs: 1544 libs: 388 tools: octopi,pamac,paru Shell: Bash v: 5.1.16
running-in: terminator inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-12-13
Last full system update: 2022-12-23
filo says
Thanks, now it Works
