Using Gnome and for some reason my login screen is on my secondary monitor and not my primary monitor.
Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ee5f72e7-75c7-4861-a5c6-9ae5039aa855 rw [email protected]
i915.force_probe=4680
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Micro-Star product: MS-7D25 v: 1.0
Mobo: Micro-Star model: PRO Z690-A WIFI DDR4(MS-7D25) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.10
date: 12/13/2021
Device-2: hidpp_battery_1 model: Logitech MK700 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x1F
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 640 high: 801 min/max: 800/6300:6400:3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 600 2: 600 3: 600 4: 601
5: 600 6: 601 7: 600 8: 601 9: 600 10: 600 11: 600 12: 600 13: 600
14: 601 15: 601 16: 600 17: 800 18: 799 19: 801 20: 800 bogomips: 144383
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915
v: kernel ports: active: DP-1,HDMI-A-1
empty: DP-2, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0
chip-ID: 8086:4680 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) Ultra HD serial: <filter>
built: 2016 res: 3840x2160 dpi: 163 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-1 model: LG (GoldStar) HDR 4K serial: <filter>
built: 2019 res: 3840x2160 dpi: 163 gamma: 1.2
OpenGL: renderer: Mesa Intel Graphics (ADL-S GT1) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-11:7
alternate: snd_sof_pci_intel_tgl chip-ID: 0c76:161e bus-ID: 00:1f.3
class-ID: 0300 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: JMTek LLC. USB PnP Audio Device type: USB
Device-3: Logitech G560 Gaming Speaker type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3:10
chip-ID: 046d:0a78 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
bus-ID: 1-14:11 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 3.18 TiB used: 556.13 GiB (17.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe SSD size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: EGFM13.2 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120
type: HDD rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
used: 404.37 GiB (43.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.15 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: 23.0 C mobo: N/A
Processes: 507 Uptime: 3m wakeups: 4 Memory: 31.15 GiB
used: 4.23 GiB (13.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1830
lib: 471 flatpak: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-01-18
Last full system update: 2022-06-25
