I have been having this bug for about 2 months, tried to worked on it multiple times and i never succeeded to resolve the issue, this is my last step before erasing and reinstalling a new Garuda. I tried to create a new user and it did not change anything.
I posted my issue in KDE FB group and no success. I do my udates daily and been working on an Arch based os since the past 5 years, Garuda for the past year.
When i login, it fails sometimes 2 or 3 times in a row, then i get into my desktop. Sometimes i have to reboot. Sometimes i get into the desktop and then a minute later it crashes and comes back to the login screen. Same login issue for the other user account.
Here is my garuda-inxi:
.%;888:8898898: philc@philc-hpz400workstation
x;XxXB%89b8:b8%b88: -----------------------------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Host: HP Z400 Workstation
.tt8x .d x88; Kernel: 6.1.68-1-lts
.@8x8; .db: xx@; Uptime: 4 hours, 15 mins
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 1578 (pacman)[stable], 8 (flatpak), 11 (snap)
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: fish 3.6.4
,888S pd! Resolution: 1920x1080 3840x2160
8X88/ q DE: KDE Plasma 5.27.10
8X88/ WM: KWin (Wayland)
GBB. WM Theme: Breeze
x%88 d888@8@X@X@X88X@@XX@@X@8@X. Theme: Breeze (KDEStory) [QT], deepin-dark [GTK2/3], Sweet-Dark [GTK4]{?3} {3} [Plasma], {?}{7}
dxXd dB8b8b8B8B08bB88b998888b88x. Icons: Breeze KDE-Story-Dark [QT], Breeze KDE-Story-Dark [GTK2/3/4]
dxx8o .@@;. Terminal: konsole 23.8.4
dx88 .t@x. Terminal Font: Hack 22
d:SS@8ba89aa67a853Sxxad. CPU: Intel(R) Xeon(R) X5675 (6) @ 3,06 GHz
.d988999889889899dd. GPU: AMD Radeon RX 550 / 550
Memory: 2,84 GiB / 11,67 GiB
ââââââââââââââââââââââââ
ââphilc@philc in ~
â°âλ garuda-inxi
Kernel: 6.1.68-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=99b6afc9-ab3d-4e2c-8f83-29439ae9a164 rw rootflags=subvol=@
ibt=off DEEPIN_GFXMODE= DEEPIN_GFXMODE=
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 7
dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Garuda Linux
Type: Desktop System: Hewlett-Packard product: HP Z400 Workstation v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: 0B4Ch v: D serial: <superuser required>
BIOS: Hewlett-Packard v: 786G3 v03.07 date: 04/06/2010
Info: model: Intel Xeon X5675 bits: 64 type: MCP arch: Nehalem level: v2
built: 2008-10 process: Intel 45nm family: 6 model-id: 0x2C (44) stepping: 2
microcode: 0x1F
Topology: cpus: 1x cores: 6 smt: disabled cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 1598 high: 1600 min/max: 1596/3060 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1596 2: 1600
3: 1596 4: 1600 5: 1596 6: 1600 bogomips: 36810
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s ports: active: DP-1,DVI-D-1 empty: HDMI-A-1
bus-ID: 0f:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 50.0 C
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-1 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: DVI-D-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 16.0.6 DRM 3.49 6.1.68-1-lts) device-ID: 1002:699f
memory: 3.91 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 550 / 550 Series (RADV POLARIS12) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:699f surfaces: xcb,xlib,wayland
device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 128 bits)
driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: Intel 82801JI HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 0f:00.1 chip-ID: 1002:aae0
API: ALSA v: k6.1.68-1-lts status: kernel-api
Device-1: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe
vendor: Hewlett-Packard driver: tg3 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 14e4:1684 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: d0c0
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 689.33 GiB used: 101.39 GiB (14.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD
serial: <filter> fw-rev: 1c87 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
tech: HDD rpm: 7200 serial: <filter> fw-rev: KC45 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 101.39 GiB (45.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.67 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 28.0 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1115
Processes: 271 Uptime: 4h 31m wakeups: 0 Memory: total: 12 GiB
available: 11.67 GiB used: 4.88 GiB (41.8%) Init: systemd v: 255
Packages: 1591 pm: pacman pkgs: 1578 libs: 441 tools: octopi,pamac,paru
pm: flatpak pkgs: 13 Shell: fish v: 3.6.4 default: Bash v: 5.2.21
Garuda (2.6.21-1):
System install date: 2022-11-13
Last full system update: 2023-12-18
ââphilc@philc in ~ took 2s
â°âλ
Thank you.
