Logged out with setting set not to log out automatically
I just moved everything to a new tower with a new power supply and all seems good, however when I went to do some dishes and came back I was logged out. I have checked my settings and as you can see they have not changed. Any thought on why I might have been logged out? Thanks
╭─locutus@Unimatrix in ~
╰─λ garuda-inxi
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b3d95ca1-50dc-4f6f-9e2e-1eb204336f28 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3404
date: 10/07/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3437 high: 3614 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3400 4: 3400 5: 3614 6: 3592 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400
12: 3400 13: 3597 14: 3400 15: 3400 16: 3400 bogomips: 108605
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 0c:00.0 chip-ID: 10de:2504 class-ID: 0300
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.38x11.14")
s-diag: 727mm (28.63")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: AOC Q2963
serial: <filter> built: 2016 res: 2560x1080 hz: 60 dpi: 97 gamma: 1.2
size: 673x284mm (26.5x11.18") diag: 730mm (28.8") modes: max: 2560x1080
min: 640x480
inactive: wayland,device-1
memory: 11.72 GiB
API: Vulkan v: 1.3.276 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 545.29.06
device-ID: 10de:2504 surfaces: xcb,xlib
Device-1: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: snd_emu10k1 v: kernel bus-ID: 08:00.0 chip-ID: 1102:0008
class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
bus-ID: 0c:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp10s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 0b:00.0
IF: enp11s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 13d3:3563
Local Storage: total: 26.89 TiB used: 16.16 TiB (60.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 29.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Crucial model: CT500P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 29.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
fw-rev: 1801 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000AS0002-1NA17Z
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5980
serial: <filter> scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion HDD
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 0003 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
used: 25.61 GiB (11.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 2 MiB (0.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-4: /var/log raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 232.8 GiB size: 232.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.95 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.6 C mobo: 32.0 C gpu: nvidia temp: 40 C
Processes: 492 Uptime: 1h 9m wakeups: 0 Memory: total: 48 GiB
available: 46.95 GiB used: 9.58 GiB (20.4%) Init: systemd v: 255
Packages: 2159 pm: pacman pkgs: 2144 libs: 585 tools: paru,pikaur,yay
pm: flatpak pkgs: 15 Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.23-1):
System install date:     2024-02-08
Last full system update: 2024-02-10
That screenshot is power management settings. Screen locking behavior is defined in Workspace Behavior > Screen Locking.
Both boxes are unchecked there as well. Seems at this point to be a one-off. I’ve been away from the system more than once since that happened for longer periods than it took me to do the dishes and it’s not logging out on its own now.
