Locked File System
I wasn’t really doing anything on my computer, messing around with a virtual machine, when it suddenly stopped working and gave me an error about not being able to read something. My next logical step was to try updating to see if it was an outdated program or something of the sort, when it gave the following error message
─popcorn@the in ~
╰─λ garuda-update
[sudo] password for popcorn:
error: failed to synchronize all databases (unable to lock database)
/usr/lib/garuda/garuda-update/main-update: line 10: /var/log/garuda/garuda-update: Read-only file system
From there I wasn’t really able to do much.
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=30e48d2f-20e2-4617-b489-df36e38ed3cd rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Mobo: ASUSTeK model: PRIME X670-P WIFI v: Rev 1.xx
UEFI: American Megatrends v: 0823 date: 11/21/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3111 high: 4840 min/max: 400/5453 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 4836 3: 400
4: 4317 5: 4302 6: 4839 7: 400 8: 4840 9: 4408 10: 3380 11: 400 12: 4821
bogomips: 112586
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3 code: Navi-33
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 8 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7480
gpu: amdgpu display-ID: 0
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7600 (radeonsi navi33
LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:7480
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 7600 (RADV NAVI33) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:7480 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0a:00.0
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: AzureWave driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0b:00.0 chip-ID: 10ec:b852
IF: wlp11s0 state: up mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 13d3:3571
Local Storage: total: 1.85 TiB used: 200.29 GiB (10.6%)
fw-rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: N/A size: 29.3 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.00
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 200.29 GiB (10.8%)
used: 200.29 GiB (10.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.5 C mobo: N/A gpu: amdgpu temp: 37.0 C
mem: 49.0 C
Memory: total: 32 GiB note: est. available: 31.09 GiB used: 4.41 GiB (14.2%)
Processes: 318 Power: uptime: 4h 34m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 1647 libs: 470
tools: octopi,pamac,paru,trizen,yay Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-01-10
Last full system update: 2024-03-23
Failed units:            linux-modules-cleanup.service man-db.service updatedb.service
Please, use forum search next time :slight_smile:
Type in terminal
fixpacman
Enter
garuda-update
Enter
Reboot
Check
