Funjord
December 13, 2022, 1:04am
1
Hey there, my boyfriend is having an issue with updating his install, from fresh it boots in fine, however once he updates, it refuses to boot and gets stuck on loading initial ramdisk.
He says that the assistant updater runs and that after that has ran, it wont boot. (I think, trying to guess from his messages.) We think it's something that the assistant updater does that bricks it and makes it unable to boot, nothing we search for seems to have a fix for this issue.
He had his system on auto update, and had been using it fine without issue until it updated recently. (Around 12/12/2022)
SGS
December 13, 2022, 1:09am
2
Welcome
Use the link
While there are many potential reasons why your installation doesn’t boot to a desktop, the primary reason is that the graphics drivers haven’t loaded correctly so your login/display manager (DM) doesn’t start. This is why you get a “black screen” or stuck at an
[ OK ] Started some service
message.
The normal reason for this is that you have the incorrect driver version for the kernel. This can happens when the mirror you are updating from is not fully synchronised, or times out, and so y…
and please, post garuda-inxi from live ISO.
Never ever use this, you must check the output from garuda-update and sometimes check the pacsave/pacnew files.
Funjord
December 13, 2022, 11:00pm
3
12System:
12Kernel 5.15.74-1-lts 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=garuda
misolabel=GARUDA_XFCE_TALON quiet systemd.show_status=1 ibt=off
systemd.unified_cgroup_hierarchy=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
12Console N/A 12Distro Garuda Linux 12base Arch Linux
12Machine:
12Type Desktop 12System ASUS 12product N/A 12v N/A 12serial N/A
12Mobo ASUSTeK 12model ROG STRIX B550-F GAMING 12v Rev X.0x 12serial <filter> 12UEFI American Megatrends
12v 2006 12date 03/19/2021
12CPU:
12Info 12model AMD Ryzen 9 5900X 12socket AM4 12bits 64 12type MT MCP 12arch Zen 3 12gen 4 12level v3 12note check
12built 2021-22 12process TSMC n7 (7nm) 12family 0x19 (25) 12model-id 0x21 (33) 12stepping 0
12microcode 0xA201009
12Topology 12cpus 1x 12cores 12 12tpc 2 12threads 24 12smt enabled 12cache 12L1 768 KiB 12desc d-12x32 KiB;
i-12x32 KiB 12L2 6 MiB 12desc 12x512 KiB 12L3 64 MiB 12desc 2x32 MiB
12Speed (MHz) 12avg 2762 12high 3700 12min/max 2200/4950 12boost enabled 12base/boost 3700/4950 12scaling
12driver acpi-cpufreq 12governor schedutil 12volts 1.1 V 12ext-clock 100 MHz 12cores 121 3700 122 2200 123 2200
124 2200 125 2200 126 2200 127 3700 128 2200 129 2200 1210 3700 1211 3700 1212 3700 1213 2200 1214 2200 1215 2200
1216 2200 1217 2200 1218 3700 1219 2200 1220 3700 1221 3700 1222 2200 1223 3700 1224 2200 12bogomips 177283
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
12Vulnerabilities
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type retbleed 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB
filling, PBRSB-eIBRS: Not affected
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] 12vendor Micro-Star MSI 12driver nvidia
12v 520.56.06 12non-free 525.xx+ 12status current (as of 2022-12) 12arch Turing 12code TUxxx
12process TSMC 12nm FF 12built 2018-22 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 16 12link-max 12gen 3
12speed 8 GT/s 12bus-ID 08:00.0 12chip-ID 10de:1e07 12class-ID 0300
12Device-2 HTC (High Tech ) Vive 12type USB 12driver snd-usb-audio,uvcvideo 12bus-ID 5-2.1.2:10
12chip-ID 0bb4:2c87 12class-ID 0102
12Display 12server X.org 12v 1.21.1.4 12compositor xfwm 12driver N/A 12tty 80x40
12API OpenGL 12Message GL data unavailable in console and glxinfo missing.
12Audio:
12Device-1 NVIDIA TU102 High Definition Audio 12vendor Micro-Star MSI 12driver snd_hda_intel 12v kernel
12bus-ID 1-9:6 12chip-ID 0d8c:0134 12pcie 12gen 1 12class-ID 0300 12speed 2.5 GT/s 12lanes 16 12link-max 12gen 3
12speed 8 GT/s 12bus-ID 08:00.1 12chip-ID 10de:10f7 12class-ID 0403
12Device-2 AMD Starship/Matisse HD Audio 12vendor ASUSTeK 12driver snd_hda_intel 12v kernel 12pcie 12gen 4
12speed 16 GT/s 12lanes 16 12bus-ID 0a:00.4 12chip-ID 1022:1487 12class-ID 0403
12Device-3 C-Media USB PnP Audio Device 12type USB 12driver hid-generic,snd-usb-audio,usbhid
12Device-4 HTC (High Tech ) Vive 12type USB 12driver snd-usb-audio,uvcvideo 12bus-ID 5-2.1.2:10
12Device-5 HTC (High Tech ) Vive 12type USB 12driver hid-generic,usbhid 12bus-ID 5-2.1.5:11
12chip-ID 0bb4:2c87 12class-ID 0300 12serial <filter>
12Sound API ALSA 12v k5.15.74-1-lts 12running yes
12Sound Server-1 PulseAudio 12v 16.1 12running no
12Sound Server-2 PipeWire 12v 0.3.61 12running yes
12Network:
12Device-1 Intel Ethernet I225-V 12vendor ASUSTeK 12driver igc 12v kernel 12pcie 12gen 2 12speed 5 GT/s 12lanes 1
12port N/A 12bus-ID 07:00.0 12chip-ID 8086:15f3 12class-ID 0200
12IF enp7s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
12Drives:
12Local Storage 12total 2.78 TiB 12used 14.07 GiB (0.5%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/nvme0n1 12maj-min 259:2 12vendor Samsung 12model SSD 980 PRO 1TB 12size 931.51 GiB 12block-size
12physical 512 B 12logical 512 B 12speed 63.2 Gb/s 12lanes 4 12type SSD 12serial <filter> 12rev 3B2QGXA7
12temp 34.9 C
12ID-2 /dev/nvme1n1 12maj-min 259:0 12vendor Intel 12model SSDPEKNW020T8 12size 1.86 TiB 12block-size
12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12type SSD 12serial <filter> 12rev 004C
12temp 30.9 C
12ID-3 /dev/sda 12maj-min 8:0 12type USB 12model SCSI 12size 7.54 GiB 12block-size 12physical 512 B
12logical 512 B 12type N/A 12serial <filter> 12rev 1.00
12Partition:
12ID-1 / 12raw-size 931.22 GiB 12size 931.22 GiB (100.00%) 12used 14.07 GiB (1.5%) 12fs btrfs
12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:4
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 608 KiB (0.2%) 12fs vfat
12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:3
12ID-3 /home 12raw-size 931.22 GiB 12size 931.22 GiB (100.00%) 12used 14.07 GiB (1.5%) 12fs btrfs
12ID-4 /var/log 12raw-size 931.22 GiB 12size 931.22 GiB (100.00%) 12used 14.07 GiB (1.5%) 12fs btrfs
12ID-5 /var/tmp 12raw-size 931.22 GiB 12size 931.22 GiB (100.00%) 12used 14.07 GiB (1.5%) 12fs btrfs
12Swap:
12Kernel 12swappiness 133 (default 60) 12cache-pressure 100 (default)
12ID-1 swap-1 12type zram 12size 62.71 GiB 12used 0 KiB (0.0%) 12priority 100 12dev /dev/zram0
12Sensors:
12System Temperatures 12cpu 34.9 C 12mobo N/A
12Fan Speeds (RPM) N/A
12Info:
12Processes 450 12Uptime 4m 12wakeups 1 12Memory 62.71 GiB 12used 3.76 GiB (6.0%) 12Init systemd 12v 252
12default graphical 12tool systemctl 12Compilers 12gcc 12.2.0 12Packages 12pm pacman 12pkgs 1185 12libs 325
12tools paru 12Client Unknown Client: systemd 12inxi 3.3.24
This is what he sent me, I'd also like to correct that he wasn't using auto updater, rather the update assistant, I misunderstood him.
He said that installing fresh from USB boots fine, though as soon as he updates it freezes at ramdisk.
TNE
December 14, 2022, 12:05am
4
They should try giving booting the installer with the free and open source drivers a shot, this kind of issue is commonly caused by the NVIDIA drivers. The setup assistant should then offer to install the NVIDIA drivers once the update is done.
Funjord
December 14, 2022, 6:21am
5
He told me that he installed with the free drivers and it booted fine, though once he ran garuda-update through the setup assistant, it gets stuck on loading ramdisk again.
Funjord
December 16, 2022, 12:47am
6
He did something which now results in this, hangs forever on that too, according to him.
Edit: Seem to have fix'd this be removing "splash" from the boot config.
Edit 2: scratch that, was a bypass. hangs again.
system
Closed
December 30, 2022, 12:48am
7
