This is absolutely unimportant, but the little penguin that ended the System Update process (after the text "System updated!") now is a little rectangle, so I guess there is some font missing or something like that. I haven't uninstalled anything nor changed the configuration of the terminal, so maybe it's a general issue. I did install the ttf-ms-fonts package some days ago, although I do not think it has anything to do. Be aware also that I use the chaotic-aur package stacer to clean the system, in case it deletes something it should not (but I've been using it for quite some time).
I've rebooted after the last update.
I'm reporting this from my desktop computer, not my laptop.
Cheers.
╰─λ inxi -Faz
System: Kernel: 5.15.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ccb67658-1e21-4b0f-b3fb-2d3914c7f62a rw
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B250-PLUS v: Rev X.0x serial: <filter> UEFI-[Legacy]: American Megatrends
v: 0304 date: 11/14/2016
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545 serial: <filter>
CPU: Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57600
Speed: 4160 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4160 2: 4192 3: 4098 4: 4100 5: 4176 6: 4083 7: 4175
8: 4136
Graphics: Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5912
Device-2: NVIDIA GP107 [GeForce GTX 1050] vendor: ASUSTeK driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Screen-1: 0 s-res: 6400x1440 s-dpi: 91 s-size: 1786x401mm (70.3x15.8") s-diag: 1830mm (72.1")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 92 size: 708x398mm (27.9x15.7") diag: 812mm (32")
Monitor-2: HDMI-1-1 res: 1920x1080 dpi: 96 size: 509x286mm (20.0x11.3") diag: 584mm (23")
Monitor-3: DP-1-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.4-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A driver: r8169
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8 bus-ID: 1-1:2
Drives: Local Storage: total: 14.1 TiB used: 199.44 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G1B0A-00H9H0 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10WD scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM005-2DP166 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5980 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Desktop size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 040B scheme: GPT
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital model: WD30EZRZ-00Z5HB0 size: 2.73 TiB block-size:
physical: 4096 B logical: 4096 B type: HDD rpm: 5400 serial: <filter> rev: 1065 scheme: MBR
Partition: ID-1: / raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 199.44 GiB (44.4%) fs: btrfs block-size: 4096 B
dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 199.44 GiB (44.4%) fs: btrfs block-size: 4096 B
ID-3: /var/log raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 199.44 GiB (44.4%) fs: btrfs
block-size: 4096 B dev: /dev/sda4 maj-min: 8:4
ID-4: /var/tmp raw-size: 449.26 GiB size: 449.26 GiB (100.00%) used: 199.44 GiB (44.4%) fs: btrfs
ID-1: swap-1 type: zram size: 15.49 GiB used: 768 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 51 C
Info: Processes: 293 Uptime: 3m wakeups: 2 Memory: 15.49 GiB used: 4.63 GiB (29.9%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: apt: 0 pacman: 1388 lib: 334 Shell: fish v: 3.3.1 default: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.08
