Hello,
My GTX 1050 Mobile is running at 1700MHz (According to GreenWithEnvy) when playing somewhat demanding games. This is making it run hot enough to make the fans spin obnoxiously loud and I were considering to limit the max frequency to lower the temperature.
I have tried to use the Coolbits method described in [ArchWiki] (NVIDIA/Tips and tricks - ArchWiki)
Which should enable me to enter a negative off-set value in Nvidia X Server Settings, but to no luck.
Using nvidia-smi -i 0 -pl to set a powerlimit does not work as it just reports
"Changing power management limit is not supported for GPU: 00000000:3A:00.0.
Treating as warning and moving on.
All done."
and neither does Nvidia-smi --lock-gpu-clocks
"Setting locked GPU clocks is not supported for GPU 00000000:3A:00.0.
Treating as warning and moving on."
All done.
╰─λ inxi -Faz
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4019034f-6f4f-46e5-acf0-a35c21988880 rw rootflags=subvol=@
Type: Convertible System: LENOVO product: 81JS v: Lenovo YOGA 730-15IWL
serial: <superuser required> Chassis: type: 31 v: Lenovo YOGA 730-15IWL
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: 9MCN27WW(V2.08)
date: 12/31/2020
ID-1: BAT1 charge: 41.9 Wh (100.0%) condition: 41.9/51.6 Wh (81.1%)
volts: 12.6 min: 11.2 model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x PABAS0241231
type: Li-ion serial: <filter> status: Full cycles: 272
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 714 high: 800 min/max: 400/1800 scaling:
driver: intel_pstate governor: powersave cores: 1: 621 2: 692 3: 704 4: 800
5: 797 6: 700 7: 700 8: 700 bogomips: 31999
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 3a:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:5 chip-ID: 04f2:b61e class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
v: 4.6 Mesa 21.3.3 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 39:00.0
IF: wlp57s0 state: up mac: <filter>
v: 0.8 bus-ID: 1-7:8 chip-ID: 8087:0025 class-ID: e001
address: <filter>
Local Storage: total: 476.94 GiB used: 99.93 GiB (21.0%)
model: MZVLB512HAJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: 5L1QEXA7 temp: 34.9 C scheme: GPT
used: 99.93 GiB (21.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.35 GiB used: 512 KiB (0.0%)
System Temperatures: cpu: 39.0 C pch: 37.0 C mobo: N/A
Processes: 292 Uptime: 20m wakeups: 3 Memory: 15.35 GiB
used: 4.03 GiB (26.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1802 lib: 538 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
