Sorry about it. I felt it was more of a theme issue and system details might not be useful.
╭─shantanu@Greyhead in ~
╰─λ garuda-inxi
Kernel: 6.7.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8c21cc27-c660-4c39-9c5e-1dc59b00ad5c rw rootflags=subvol=@
resume=UUID=6b675d04-b6c5-4b3f-838d-4b4f19888841 loglevel=3 ibt=off
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Convertible System: ASUSTeK product: ROG Flow X16 GV601RM_GV601RM
Mobo: ASUSTeK model: GV601RM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GV601RM.310
date: 07/06/2022
ID-1: BAT0 charge: 83.0 Wh (100.0%) condition: 83.0/90.0 Wh (92.2%)
power: 41.3 W volts: 16.0 min: 16.0 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging
Device-1: hid-0018:04F3:2FC2.0003-battery model: ELAN9008:00 04F3:2FC2
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 7 6800HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 841 high: 3358 min/max: 400/4785 scaling:
4: 400 5: 400 6: 400 7: 3358 8: 400 9: 1435 10: 400 11: 400 12: 400
13: 1483 14: 400 15: 1397 16: 1397 bogomips: 102214
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2 empty: DP-2,
DP-3, DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 09:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 49.0 C
Device-3: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 0408:30c3
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-2 res: 1707x1067 size: N/A modes: N/A
surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.1
rembrandt LLVM 16.0.6 DRM 3.57 6.7.7-zen1-1-zen) device-ID: 1002:1681
API: Vulkan v: 1.3.276 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.2-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia
v: 550.54.14 device-ID: 10de:2520 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.2-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.5
bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.7-zen1-1-zen status: kernel-api tools: N/A
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0489:e0e2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 953.87 GiB used: 420.04 GiB (44.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA1T0TFH
lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA001 temp: 32.9 C
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 16.89 GiB (8.4%)
fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
ID-2: /boot/efi raw-size: 512.7 MiB size: 511.7 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 514.03 GiB size: 514.03 GiB (100.00%)
used: 403.15 GiB (78.4%) fs: btrfs dev: /dev/nvme0n1p10 maj-min: 259:10
ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
used: 16.89 GiB (8.4%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: swap-2 type: zram size: 14.88 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.9 C mobo: 40.0 C gpu: amdgpu temp: 51.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 14.89 GiB used: 4.69 GiB (31.5%)
Processes: 419 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 5.89 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1523 libs: 428 tools: octopi,pamac,paru
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-10-09
Last full system update: 2024-03-03
Failed units:type or paste code here
