Hi garuda community
I'm encountering a problem with libvirt hooks. When I run my VM, the qemu hooks I config are not called at start and stop of VM.
About the VM :
- It runs on w10
- Use GPU, NVME and TPM passthrough
- Pass sound to host via pipewire
- Pass mouse and keyboard via Evdev
What I do :
- create
/etc/libvirt/hooksfolder - download a common script that let you split config in different folder : Qemu Script - Pastebin.com
- correctly put my programs in folder that follow this structure :
/etc/libvirt/hooks/
β qemu
ββββqemu.d/win10/
ββββrelease/end/
β β monitor.sh
ββββstarted/begin/
β carla.sh
β monitor.sh
- restart deamon and pc
- try without this script
- put all scripts the execute permission to all users
Output of Garuda Inxi : garuda-inxi - Pastebin.com
Log of my libvirt VM : win10
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=586673e3-ddbc-449a-a85d-3e384596dd60 rw rootflags=subvol=@
vfio-pci.ids=10de:2216,10de:1eaf,1bb1:5016 module_blacklist=nouveau quiet
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4002
date: 06/15/2021
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4200 high: 4206 min/max: 2200/4200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4202 2: 4199
3: 4206 4: 4205 5: 4200 6: 4200 7: 4200 8: 4200 9: 4197 10: 4200 11: 4200
12: 4200 bogomips: 100806
Device-1: AMD Hawaii PRO [Radeon R9 290/390] driver: radeon v: kernel
alternate: amdgpu arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm
built: 2013-17 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: DP-1,HDMI-A-1 empty: DVI-D-1,DVI-D-2 bus-ID: 08:00.0
chip-ID: 1002:67b1 class-ID: 0300 temp: 65.0 C
Device-2: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
driver: vfio-pci v: N/A alternate: nouveau non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 09:00.0 chip-ID: 10de:2216 class-ID: 0300
alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Acer XF240H
serial: <filter> built: 2017 res: 1920x1080 dpi: 92 gamma: 1.2
Monitor-2: HDMI-A-1 mapped: HDMI-0 pos: right model: Acer XB271HU A
serial: <filter> built: 2018 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
API: OpenGL v: 4.5 Mesa 22.3.3 renderer: HAWAII ( LLVM 14.0.6 DRM 2.50
6.1.5-zen2-1-zen) direct render: Yes
Device-1: AMD Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
driver: snd_hda_intel v: kernel pcie: bus-ID: 5-3.1:5 chip-ID: 0a12:123d
gen: 3 speed: 8 GT/s class-ID: 0300 serial: <filter> lanes: 8 link-max:
lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:aac8 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
link-max: lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Cambridge Silicon Radio eppfun AK3040 type: USB
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
IF-ID-1: br0 state: down mac: <filter>
Local Storage: total: 2.5 TiB used: 72.29 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: MBR
used: 72.23 GiB (31.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.53 GiB used: 2.44 GiB (15.7%)
System Temperatures: cpu: 39.0 C mobo: 38.0 C gpu: radeon temp: 65.0 C
Processes: 405 Uptime: 6h 31m wakeups: 0 Memory: 15.53 GiB
used: 4.2 GiB (27.0%) Init: systemd v: 252 default: graphical
pkgs: 1842 libs: 527 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-10-22
Last full system update: 2023-01-14 β»
Failed units: NetworkManager-wait-online.service
