Libudev.so.1 Issue with hypland
Please I need help on running a rust app. I get the following error:
 error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
Please I need help. Here are details of my laptop:
  Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=363bfa48-1d0d-4824-88fa-2cd6a45ee7b7 rw rootflags=subvol=@
    quiet rd.luks.uuid=1bf4b8cc-c0c8-4fb1-8f2a-49bf1827587b
    rd.luks.uuid=8b88c647-0e0f-46e4-9504-9473eca142ac
    resume=/dev/mapper/luks-8b88c647-0e0f-46e4-9504-9473eca142ac loglevel=3
  Desktop: Hyprland v: 0.35.0-83-g8c361363 with: waybar tools:
    avail: swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: LENOVO product: 82MS v: Yoga Slim 7 Pro 14ACH5
    serial: <superuser required> Chassis: type: 10 v: Yoga Slim 7 Pro 14ACH5
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76463WIN
    serial: <superuser required> part-nu: LENOVO_MT_82MS_BU_idea_FM_Yoga Slim 7
    Pro 14ACH5 uuid: <superuser required> UEFI: LENOVO v: GZCN30WW
    date: 07/04/2022
  ID-1: BAT0 charge: 50.6 Wh (100.0%) condition: 50.6/61.0 Wh (83.0%)
    volts: 17.4 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
    status: full cycles: 442
  Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000B
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 675 high: 2431 min/max: 400/4280 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 1679 3: 400
    4: 400 5: 400 6: 400 7: 2431 8: 400 9: 400 10: 400 11: 400 12: 400
    bogomips: 79053
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2
    bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 45.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:5419
    compositor: Hyprland v: 0.35.0-83-g8c361363 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
    display-ID: 1
  Monitor-1: eDP-1 model: BOE Display 0x0931 built: 2020 res: 2240x1400
    hz: 60 dpi: 188 gamma: 1.2 scale: 1 size: 302x189mm (11.89x7.44")
    diag: 356mm (14") ratio: 16:10 modes: max: 2240x1400 min: 640x480
  API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.1-arch1.1
    device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.0.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
    speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw89_8852ae v: N/A modules: rtw_8852ae pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8852
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:4852
  Report: btmgmt ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 23.54 GiB (4.9%)
    model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 3L1QEXF7 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 461.79 GiB size: 461.79 GiB (100.00%)
    used: 23.54 GiB (5.1%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-1bf4b8cc-c0c8-4fb1-8f2a-49bf1827587b
    used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 461.79 GiB size: 461.79 GiB (100.00%)
  ID-4: /var/log raw-size: 461.79 GiB size: 461.79 GiB (100.00%)
  ID-5: /var/tmp raw-size: 461.79 GiB size: 461.79 GiB (100.00%)
  ID-1: swap-1 type: partition size: 14.85 GiB used: 0 KiB (0.0%)
    mapped: luks-8b88c647-0e0f-46e4-9504-9473eca142ac
  ID-2: swap-2 type: zram size: 13.5 GiB used: 5.72 GiB (42.3%)
  System Temperatures: cpu: 54.9 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Memory: total: 16 GiB note: est. available: 13.5 GiB used: 8.79 GiB (65.1%)
  Processes: 406 Power: uptime: 1d 15h 10m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 5.39 GiB services: upowerd
  Packages: 1845 pm: nix-default pkgs: 51 pm: nix-sys pkgs: 0 pm: nix-usr
    pkgs: 562 libs: 159 pm: pacman pkgs: 1232 libs: 376 tools: pacseek,paru,yay
    Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
    v: 3.7.0 running-in: foot inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2024-02-21
  Last full system update: 2024-02-26 ↻
  Failed units:            systemd-vconsole-setup.service
Summary
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
First of all, this means that a reboot is pending. Just in case…
Then, which package triggers this error and how did you install it?
I am try run a bevy rust app using cargo run
I’m sorry but all this has nothing to deal with Garuda or Arch packages.
Maybe check this, where that lib Is mentioned
Which reminds to this
But I don’t see the dependencies I would expect, which could be systemd-libs. Could!
