Librewolf no longer respects my Window rules.
I have Window Actions set to: Activate and raise.
All windows beside Librewolf respect the setting.
If I am in another application and click on Librewolf it will not raise - unless I click the titlebar. If I click on the window it will also pass click on the window.
I installed
plasma-browser-integration
and
librewolf-extension-plasma-integration -but:
ps. I played around with Window settings and turned on “Ignore Window Geometry: Force” The window can still be dragged when it should lock. It seems Librewolf is missing some connection to the system.
How do I get Librewolf to abide by Activate and raise.
Kernel: 6.12.16-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cfe58ff1-10f6-4a0f-bf00-e7c82f3b3a89 rw rootflags=subvol=@
quiet resume=UUID=804a5b91-748b-4e0e-9b50-cd4994cf4a32 loglevel=3
snd_hda_intel.dmic_detect=0 ibt=off
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: Dell product: Precision 5520 v: N/A
Mobo: Dell model: 0R6JFH v: A00 serial: <superuser required> part-nu: 07BF
uuid: <superuser required> UEFI: Dell v: 1.40.0 date: 09/03/2024
ID-1: BAT0 charge: 39.0 Wh (65.8%) condition: 59.3/97.1 Wh (61.1%)
volts: 11.5 min: 11.8 model: LGC-LGC8.33 DELL 5XJ28 type: Li-ion
Info: model: Intel Core i7-7820HQ bits: 64 type: MT MCP arch: Kaby Lake
Speed (MHz): avg: 900 min/max: 800/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 bogomips: 46419
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:591b
Device-2: NVIDIA GM107GLM [Quadro M1200 Mobile] vendor: Dell
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:13b6 class-ID: 0302
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:3
chip-ID: 0c45:6713 class-ID: 0e02
Monitor-1: eDP-1 model: Sharp 0x1453 built: 2015 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 141 gamma: 1.2 size: 346x194mm (13.62x7.64")
diag: 397mm (15.6") ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 15.17 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: N/A device-ID: 8086:591b
surfaces: xcb,xlib device: 1 type: discrete-gpu name: Quadro M1200
driver: N/A device-ID: 10de:13b6 surfaces: xcb,xlib device: 2 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
surfaces: xcb,xlib
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_soc_avs v: kernel
alternate: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
API: ALSA v: k6.12.16-1-lts status: kernel-api
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b2 class-ID: 0280
wpa_supplicant
Local Storage: total: 1.86 TiB used: 1.39 TiB (74.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42AZS6AC temp: 34.9 C
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 1.39 TiB (75.7%)
used: 20.1 MiB (6.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 1.39 TiB (75.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.07 GiB used: 2.28 GiB (7.3%)
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 50.0 C pch: 41.5 C mobo: 48.0 C
Fan Speeds (rpm): cpu: 2485 fan-2: 2509
Memory: total: 32 GiB note: est. available: 31.07 GiB used: 9.24 GiB (29.7%)
Processes: 377 Power: uptime: 15h 48m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 fails: 94 hibernate: suspend
avail: platform, shutdown, reboot, test_resume image: 12.37 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: 1793 pm: pacman pkgs: 1792 libs: 468 tools: octopi,paru
pm: flatpak pkgs: 1 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-05-31
Last full system update: 2025-02-26 ↻
Failed units: nmb.service nvidia-powerd.service systemd-hybrid-sleep.service
