Librewolf issues
Kernel: 6.8.8-AMD-znver2 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver2
root=UUID=ba57fdb3-aa0d-421e-bb33-f2a65aed2c1b rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P5.50
date: 10/13/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
Device-2: hidpp_battery_1 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3793 high: 3800 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 17: 3800 18: 3800 19: 3648
20: 3800 21: 3800 22: 3800 23: 3800 24: 3800 bogomips: 182495
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,Writeback-1
bus-ID: 10:00.0 chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-arch1.2
navi31 LLVM 17.0.6 DRM 3.57 6.8.8-AMD-znver2) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.0.6-arch1.2
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab30
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.8-AMD-znver2 status: kernel-api tools: N/A
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0029
Local Storage: total: 19.1 TiB used: 5.66 TiB (29.7%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Seagate model: FireCuda 520 SSD
ZP500GM30002 size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: STNSC014
temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate model: FireCuda 520 SSD
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
model: WUH721818ALE6L4 size: 16.37 TiB block-size: physical: 4096 B
fw-rev: W232 scheme: GPT
used: 57.08 GiB (12.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 125.74 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.4 C mobo: N/A gpu: amdgpu temp: 48.0 C
mem: 54.0 C
Memory: total: 128 GiB note: est. available: 125.74 GiB
used: 6.42 GiB (5.1%)
Processes: 489 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.29 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1677 libs: 476 tools: octopi,pacseek,paru
Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-05-03
Last full system update: 2024-05-08
I’m happy to say that a fresh install of the new ISO (dr460nized gaming) went perfectly.
There were several minor issues afterward that I was able to fix myself, except for one, which is what I’m hoping to get some insight on.
The first issue was that there was no spellchecker installed for Libreoffice (en-us package in my case specifically) so spell checking didn’t work. Easily fixable by installing the appropriate hunspell package.
Second was that the font in Akregator’s web browser view / article view was blurry or messed up. Still readable, but painfully so. Turned out it’s a bug still present (that isn’t supposed to be) with fractional scaling in Qt. (A workaround is to use the QT_SCALE_FACTOR_ROUNDING_POLICY=Round environmental variable.) I just switched my scaling on my 4K displays from the default 175% to 200% and adjusted the font size. Fixed.
But the third minor issue I’m having is that I use Librewolf and I installed the librewolf-extension-plasma-integration (1.9-1) package from the repos because Mozilla never approved the 1.9 version when it was submitted to them last year.
However, it results in this bug:
https://bugs.kde.org/show_bug.cgi?id=476967
“Failed to connect to the native host.
Make sure the ‘plasma-browser-integration’ package is installed correctly and that you are running Plasma 5.13 or later.
No such native application
org.kde.plasma.browser_integration”
This says a solution is to link these files. But since I don’t have that file in my /etc/apparmor.d/ directory (on account of not having firefox installed), IDK how to proceed.
Any ideas?
None of your problems has to do with Garuda Linux.
I changed the topic header.
Found a solution to this issue. (Create these folders first if you do not have any of them.)
sudo cp /usr/lib/mozilla/native-messaging-hosts/org.kde.plasma.browser_integration.json /usr/lib/librewolf/native-messaging-hosts/org.kde.plasma.browser_integration.json
