Hello
I want to change the size of my scroll bar in Libre office because it is way to small (almost invisible)
see this Screen shot:
by the way I am using an 4k Monitor
What can I do to change this thing in Garuda Linux?
it seems to be a quite common Problem
but there is no real Solution that works on my Machine
Thanks for the Help in advance
THIS is my Libre Office version:
Version: 24.2.4.2 (X86_64) / LibreOffice Community
Build ID: 420(Build:2)
CPU threads: 16; OS: Linux 6.9; UI render: default; VCL: kf6 (cairo+wayland)
Locale: de-DE (de_DE.UTF-8); UI: en-US
24.2.4-2
Calc: threaded
This is my Garuda INXI
system:
root=UUID=316fbee6-4f37-402a-ab2b-cc4bd7da6812 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop System: Gigabyte product: X470 AORUS GAMING 5 WIFI v: N/A
Mobo: Gigabyte model: X470 AORUS GAMING 5 WIFI-CF v: x.x
serial: <superuser required> uuid: <superuser required> BIOS: American
Megatrends LLC. v: F60h date: 02/04/2021
Device-1: hidpp_battery_0 model: Logitech Illuminated Living-Room Keyboard
K830 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3792 high: 4242 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3745 2: 3700
3: 3700 4: 3700 5: 3814 6: 4192 7: 3700 8: 4242 9: 3947 10: 3700 11: 3700
12: 3836 13: 4001 14: 2873 15: 4129 16: 3700 bogomips: 118399
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: Gigabyte driver: nvidia
v: 555.58 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1 empty: DP-2, DP-3, HDMI-A-1, HDMI-A-2,
HDMI-A-3 bus-ID: 0a:00.0 chip-ID: 10de:1b06 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-1 res: 2194x1234 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 1 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm,device-0
API: OpenGL v: 4.5 vendor: mesa v: 24.1.2-arch1.1 note: incomplete (EGL
sourced) renderer: llvmpipe (LLVM 17.0.6 256 bits)
Device-1: NVIDIA GP102 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
chip-ID: 10de:10ef class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
Local Storage: total: 6.37 TiB used: 1.86 TiB (29.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 42.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000VN008-2DR166
tech: HDD rpm: 5980 serial: <filter> fw-rev: SC60 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 QVO 1TB
ID-1: / raw-size: 686.24 GiB size: 686.24 GiB (100.00%)
used: 65.88 GiB (9.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /home raw-size: 686.24 GiB size: 686.24 GiB (100.00%)
ID-3: /var/log raw-size: 686.24 GiB size: 686.24 GiB (100.00%)
ID-4: /var/tmp raw-size: 686.24 GiB size: 686.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 26.8 MiB (0.1%)
System Temperatures: cpu: 52.1 C mobo: N/A
Memory: total: 32 GiB available: 31.29 GiB used: 10.93 GiB (34.9%)
Processes: 468 Power: uptime: 2h 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: 1910 pm: pacman pkgs: 1874 libs: 509 tools: paru pm: flatpak
pkgs: 36 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-04-29
Last full system update: 2024-07-03 ā»
