Issue:
I have installed KDE edition and so far everything works good. However, i have minor issue with libreoffice-fresh
- In tools -> Options --> View --> Icon Style - Cannot change any other icon style other than "Breeze (dark)
- In tools --> Options --> Load/Save --> General --> Always Save as --> Cannot change it
In past i was able to achieve it, but i did fresh install recently and finding this issue. I have looked upon forums and searched externally also, but could not find any resolution to it.
Any help or guidance will be much appreciated.
Output of inxi -Faz
System: Kernel: 5.14.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a07dbd70-9428-4b82-8f09-14761537bad7 rw [email protected] quiet splash
resume=UUID=fbab5f42-f082-438b-9415-bed4021ab9d2 loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: Dell product: OptiPlex 3050 v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Dell model: 0JP3NX v: A01 serial: <filter> UEFI: Dell v: 1.17.0
date: 07/20/2021
CPU: Info: Dual Core model: Intel Core i3-6100T bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 5E (94) stepping: 3 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25599
Speed: 3197 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 3197 2: 3189 3: 3175
4: 3166
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
Device-2: AVerMedia Live Streamer CAM 313 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-4.1:4 chip-ID: 07ca:313a class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
Monitor-1: DP1 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x13.0")
diag: 865mm (34.1")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Sound Server-1: ALSA v: k5.14.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0
chip-ID: 8086:24f3 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-9:5 chip-ID: 8087:0a2b class-ID: e001
RAID: Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:17.0 chip-ID: 8086.2822 rev: class-ID: 0104
Drives: Local Storage: total: 338.13 GiB used: 39.95 GiB (11.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 0100 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra size: 114.56 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00
Partition: ID-1: / raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 19.68 GiB (9.5%)
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 19.68 GiB (9.5%)
ID-4: /var/log raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 19.68 GiB (9.5%)
ID-5: /var/tmp raw-size: 206.38 GiB size: 206.38 GiB (100.00%) used: 19.68 GiB (9.5%)
ID-1: swap-1 type: partition size: 16.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 15.39 GiB used: 89 MiB (0.6%) priority: 100
Sensors: System Temperatures: cpu: 66.0 C mobo: 27.8 C
Info: Processes: 312 Uptime: 10h 45m wakeups: 3 Memory: 15.39 GiB used: 7.63 GiB (49.6%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1322 lib: 346 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
