**My LibreCAD **
opens in a portrait format and wont resize. When I click the Maximize button it stays open in portrait and I need to use Alt while dragging the mouse to see the bottom of the screen. It wont drag bigger with corners nor can I drag the bottom to make the window smaller.
I have been on the LibreCAD chat to find resolution but they are saying it is with Garuda
Chat is here
Blockquote Version: 2.2.0-rc4-23-ge3fae3dc4
Compiler: GNU GCC 12.2.0
Compiled on: Dec 6 2022
Qt Version: 5.15.7
Boost Version: 1.80.0
System: Garuda Linux
0x3537d76a:
Chat is here
That link is not publicly accessible, it directs to a login page for Zulip.
Can you provide more information please? Post the output of garuda-inxi for starters.
What was your method for installing this program?
A screenshot illustrating the issue might be helpful.
Kernel: 5.15.81-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b5c6166b-9eaf-4020-98e9-32d928b43502 rw rootflags=subvol=@
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire ES1-531 v: V1.11
serial:
Mobo: Acer model: Aspire ES1-531 v: V1.11 serial:
UEFI-[Legacy]: Insyde v: 1.11 date: 07/21/2015
ID-1: BAT0 charge: 27.2 Wh (100.0%) condition: 27.2/36.7 Wh (74.2%)
volts: 12.6 min: 11.4 model: LGC AC14B18J type: Li-ion serial:
status: full
Info: model: Intel Celeron N3050 bits: 64 type: MCP arch: Airmont level: v2
built: 2015-17 process: Intel 14nm family: 6 model-id: 0x4C (76) stepping: 3
microcode: 0x368
Topology: cpus: 1x cores: 2 smt: cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1028 high: 1149 min/max: 480/2160 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1149 2: 907
bogomips: 6400
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics vendor: Acer Incorporated ALI driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1
Device-2: Chicony VGA Webcam type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 04f2:b47f class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: LG Display 0x0456 built: 2014 res: 1366x768 hz: 60
dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
missing.
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
Sound API: ALSA v: k5.15.81-1-lts running: yes
speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 01:00.0 chip-ID: 10ec:8168
IF: enp1s0 state: down mac:
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wlp2s0 state: up mac:
Device-1: Lite-On Atheros AR3012 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5.1:15 chip-ID: 04ca:300b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 6 state: up address:
Local Storage: total: 931.51 GiB used: 102.35 GiB (11.0%)
model: WD10SPZX-00Z10T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial:
rev: 1A01 scheme: GPT
ID-1: / raw-size: 175.39 GiB size: 175.39 GiB (100.00%)
used: 102.35 GiB (58.4%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
ID-2: /home raw-size: 175.39 GiB size: 175.39 GiB (100.00%)
ID-3: /var/log raw-size: 175.39 GiB size: 175.39 GiB (100.00%)
ID-4: /var/tmp raw-size: 175.39 GiB size: 175.39 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.59 GiB used: 252 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 19.92 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 232 Uptime: 17h 51m wakeups: 4 Memory: 7.59 GiB
used: 3.3 GiB (43.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1586
libs: 387 tools: octopi,pamac,paru Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-09-16
Last full system update: 2022-12-06
Windows dual boot:
The garuda-inxi output got cut off, there should be a lot more information in there.
Thanks for the screenshot, I had meant a screenshot showing the program with the issue though so we can see what is happening.
Try to temporarily change your theme to see if it has effect. Source:
xfce, window-manager
Hey thanks this is solved. I did something right lol
system
Closed
16 December 2022 02:36
7
