Hi,
Team Garuda,
Since today morning I'm unable to use Libre office, I had Libre Office 'fresh' installed from Setup assistant so I tried reinstalling both Fresh and Still Version but to no avail...
I tried running using konsole and the output is:
╭─valiant-aj@ad in ~
╰─λ libreoffice
javaldx: Could not find a Java Runtime Environment!
Warning: failed to read path from javaldx
terminate called after throwing an instance of 'com::sun::star::deployment::DeploymentException'
Unspecified Application Error
output when tried running in safe mode:
╭─valiant-aj@ad in ~ took 584ms
[🔴] × libreoffice --safe-mode
similar issue was posted in Arch Repository as well :
https://bbs.archlinux.org/viewtopic.php?id=206869
My Garuda-inxi :
╭─valiant-aj@ad in ~ took 602ms
[🔴] × garuda-inxi
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e0c0b2d8-9e53-48f4-8fc0-da6b28f10b21 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: PRO H610M-G DDR4 (MS-7D46) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.A0
date: 01/09/2023
Info: model: 12th Gen Intel Core i3-12100 bits: 64 type: MT MCP
microcode: 0x2C
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1737 high: 3300 min/max: 800/5500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 801 3: 800 4: 800
5: 3300 6: 3300 7: 800 8: 3300 bogomips: 52838
Device-1: Intel Alder Lake-S GT1 [UHD Graphics 730] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3,
HDMI-A-4, HDMI-A-5 bus-ID: 00:02.0 chip-ID: 8086:4692 class-ID: 0300
Monitor-1: DP-2 model: Lenovo G24-20 serial: <filter> built: 2021
res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel UHD Graphics 730
(ADL-S GT1) direct-render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
Device-2: Lite-On Dell Wireless Device type: USB
driver: hid-generic,usbhid bus-ID: 1-9.2:8 chip-ID: 04ca:00bd class-ID: 0301
driver: btusb v: 0.8 bus-ID: 1-9.1:7 chip-ID: 0a12:0001 class-ID: e001
address: <filter>
Local Storage: total: 465.76 GiB used: 119.46 GiB (25.6%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234100WD temp: 39.9 C scheme: GPT
used: 119.46 GiB (25.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 261 Uptime: 3h 12m wakeups: 0 Memory: 7.55 GiB
used: 4.51 GiB (59.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1307
libs: 358 tools: octopi,pamac,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-24
Last full system update: 2023-02-24
