Help i am trying to use Coral after shoot pro but this is the wairning i get
any good trick to get this fixed
Install Path: /opt/AfterShot3(64-bit)
LD_PATH: /opt/AfterShot3(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS:
./AfterShot: error while loading shared libraries: libgstreamer-0.10.so.0: cannot open shared object file: No such file or directory
There is a whole lot of information missing here.
Apart from the required garuda-inxi, it would be important to understand what package precisely you’re trying to install, taken from where, how you’re installing it, etc.
Without knowing this application, I think you could try the package in the AUR:
Because it has as dependency gstreamer, which provides that missing library.
First try installing it with a helper. E.g.
paru aftershotpro3
But I see in the comments that you might have troubles, when building, exactly with that dep.
If so, try the manual build in the second comment (from electricprism). Use micro instead of vim…
