I have just tried to update and the following message has been displayed:
libpqmarble and libmarble-git are in conflict (libmarble). Remove libmarble-git? [y/N]
Should I remove libmarble-git?
```text
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=e0aa6bf1-e32d-48b2-a659-01e4322f83f8 rw rootflags=subvol=@ quiet quiet
resume=UUID=31f5f81c-4fb3-4a39-893a-3e7c25a0feb6 loglevel=3 ibt=off
Desktop: GNOME v: 45.0 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: X513UA.312 date: 04/26/2022
ID-1: BAT0 charge: 14.5 Wh (36.8%) condition: 39.4/42.1 Wh (93.7%) power: 10.9 W volts: 11.8
min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: discharging cycles: 537
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 981 high: 1397 min/max: 400/4056 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 1397 2: 400 3: 1396 4: 400 5: 400 6: 400 7: 1397 8: 1397 9: 1397
10: 1397 11: 1397 12: 400 bogomips: 50308
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 38.0 C
Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1 compositor: gnome-shell
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: AMD Radeon Graphics
(RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2 device-ID: 1002:164c
surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
IF-ID-1: enp3s0f3u3 state: up speed: 150 Mbps duplex: half mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10 status: discoverable: no
pairing: no
Device-2: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
Report: ID: hci1 rfk-id: 3 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: <filter> bt-v: 5.3 lmp-v: 12 status: discoverable: no pairing: no
Local Storage: total: 476.94 GiB used: 187.03 GiB (39.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
fw-rev: FXV7101Q temp: 29.9 C scheme: GPT
ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 9.3 GiB (6.3%) fs: btrfs
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 321.45 GiB size: 321.45 GiB (100.00%) used: 177.73 GiB (55.3%) fs: btrfs
ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 9.3 GiB (6.3%) fs: btrfs
ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 9.3 GiB (6.3%) fs: btrfs
ID-1: swap-1 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): cpu: 0
Processes: 360 Uptime: 10m wakeups: 1 Memory: total: 8 GiB note: est. available: 7.15 GiB
used: 2.85 GiB (39.8%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1398 libs: 408 tools: pamac,paru Client: shell wrapper
v: 5.1.16-release inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2022-12-05
Last full system update: 2023-10-12
Failed units: cpupower.service
