While running garuda-update I am getting this error:
:: installing libbpf (1.0.1-1) breaks dependency 'libbpf.so=0-64' required by qemu-arch-extra-git
Garuda-inxi
Kernel: 5.19.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
serial: Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial:
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 37.1 Wh (82.1%) condition: 45.2/51.6 Wh (87.6%)
volts: 11.6 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
gen: core 9 level: v3 built: 2018 process: Intel 14nm family: 6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1250 high: 2600 min/max: 800/4500 scaling:
5: 2600 6: 2600 7: 800 8: 800 9: 2600 10: 800 11: 800 12: 800
bogomips: 62399
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:3
chip-ID: 04f2:b695 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.1.7 direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
Sound Server-1: ALSA v: k5.19.10-zen1-1-zen running: yes
IF: wlo1 state: up mac:
vendor: Micro-Star MSI driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
IF: enp3s0 state: down mac:
IF-ID-1: virbr0 state: down mac:
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
address:
Local Storage: total: 1.38 TiB used: 545.04 GiB (38.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial:
rev: 20140000 temp: 36.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial:
rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 44.89 GiB
(30.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 44.89
GiB (30.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 44.89
ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%) used: 44.89
ID-1: swap-1 type: zram size: 15.47 GiB used: 2.23 GiB (14.4%)
System Temperatures: cpu: 46.0 C pch: 50.0 C mobo: N/A
Processes: 486 Uptime: 4d 23h 49m wakeups: 17 Memory: 15.47 GiB used: 4.74
GiB (30.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1510 libs: 441
tools: octopi,paru Shell: fish v: 3.5.1 running-in: alacritty inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-07-14
Last full system update: 2022-10-01 ↻
Is partially upgraded: Yes
Failed units: archlinux-keyring-wkd-sync.service
How should I proceed?
