Lib32-mangohud and mangohud in conflict "breaking" upgrade
(33/33) checking keys in keyring [------------------------------------] 100%
(33/33) checking package integrity [------------------------------------] 100%
(33/33) loading package files [------------------------------------] 100%
(33/33) checking for file conflicts [------------------------------------] 100%
/usr/bin/mangoplot exists in both ‘lib32-mangohud’ and ‘mangohud’
removing lib32-mangohud(either using -Rdd or just -R) does indeed allow the upgrade of the VMs i use to test updates, however i am not sure what the consequences might be for gaming with the hud.
this error occurred also on the “testbed”(kde-dragonized) vm i created that has never had the clean/setup/etc commands performed
console’s garuda-inxi, i didn’t do the bypass on my console
╭─javabean@mihoshi in ~ via  v8.2.10 via  v3.11.5 as 🧙 took 33s
[[🔴]|[]] =>  ╰─λ garuda-inxi &| tee ~/update-logs/$(date +%Y-%m-%d--%H-%M)-inxi.txt
Kernel: 6.5.5-AMD-znver2 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver2
root=UUID=af8a89ce-dde7-4f59-9555-3606af1da2d7 rw rootflags=subvol=@
loglevel=3 quiet ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASRock model: A520M-HDV serial: <superuser required>
UEFI: American Megatrends LLC. v: P3.00 date: 06/29/2023
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3904 high: 3978 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3900 2: 3900
3: 3900 4: 3900 5: 3900 6: 3900 7: 3978 8: 3900 9: 3900 10: 3900 11: 3900
12: 3900 13: 3900 14: 3900 15: 3900 16: 3900 bogomips: 124614
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2,DVI-D-1 bus-ID: 05:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 54.0 C
s-diag: 1055mm (41.54")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,left
model: Samsung C32F391 serial: <filter> built: 2018 res: 1920x1080 hz: 60
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung C32F391
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.8-arch1.1 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 16.0.6 DRM 3.54 6.5.5-AMD-znver2) direct-render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.5.5-AMD-znver2 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.29 TiB used: 1.58 TiB (69.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: SVN139B temp: 31.9 C
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
used: 135.18 GiB (29.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
ID-4: /var/log raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 4.99 GiB (32.1%)
ID-2: swap-2 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 35.5 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (rpm): fan-1: 1218 fan-2: 1416 fan-3: 0 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 717
Processes: 396 Uptime: 23h 23m wakeups: 0 Memory: total: 16 GiB
available: 15.55 GiB used: 13.42 GiB (86.3%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2544 libs: 615 tools: octopi,pamac,paru
inxi: 3.3.29
System install date:     2022-05-31
Last full system update: 2023-09-26
Failed units:            bluetooth-autoconnect.service
It was already notified. Let’s see…
By-the-way, I see the update triggering the problem was from one hour ago :wink: :astonished:
i guess i will just have to grumble, i did look here to see if anyone posted the issue HERE… i should probably also watch the arch bugtracker… so much to monitor
From the little I understand about development, I see that mangoplot is a (new) python file, which therefore I think might be common between ‘lib32-mangohud’ and ‘mangohud’.
In my opinion, a
garuda-update -- --overwrite '*'
might be fine for the moment.
seems to be something odd with that command right now
sudo SKIP_MIRRORLIST=true garuda-update – --overwrite ‘*’ &| tee ~/update-log-test.txt
SKIP_MIRRORLIST=true is used to avoid beating on the normal server by locking in my pacoloco cache
error: target not found: Documents
warning: 'Documents' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: Downloads
warning: 'Downloads' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: Music
warning: 'Music' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: Pictures
warning: 'Pictures' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: Public
warning: 'Public' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: Templates
warning: 'Templates' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: test
warning: 'test' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: update-log-test.txt
warning: 'update-log-test.txt' is a file, did you mean -U/--upgrade instead of -S/--sync?
error: target not found: Videos
warning: 'Videos' is a file, did you mean -U/--upgrade instead of -S/--sync?
garuda-inxi of this vm
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: kvm-clock available: hpet,acpi_pm
root=UUID=8296b2c4-d741-4e6b-9ff1-0980f8f38fe4 rw rootflags=subvol=@
Type: Kvm System: QEMU product: Standard PC (i440FX + PIIX, 1996)
v: pc-i440fx-7.2 serial: <superuser required> Chassis: type: 1
Mobo: N/A model: N/A serial: N/A BIOS: SeaBIOS
v: rel-1.16.1-0-g3208b098f51a-prebuilt.qemu.org date: 04/01/2014
Info: model: Common KVM bits: 64 type: MCP arch: K8 level: v1
built: 2004-2008 process: AMD 65-130nm family: 0xF (15) model-id: 6
stepping: 1 microcode: 0x1000065
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 512 KiB
desc: d-4x64 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 3800 min/max: N/A cores: 1: 3800 2: 3800 3: 3800 4: 3800
bogomips: 30399
Flags: ht lm nx pae sse sse2 sse3
Device-1: vendor: Red Hat driver: bochs-drm v: N/A alternate: bochs ports:
active: Virtual-1 empty: none bus-ID: 00:02.0 chip-ID: 1234:1111
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: bochs-drm display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: Virtual-1 model: QEMU Monitor built: 2014 res: 1280x800 hz: 75
dpi: 100 gamma: 1.2 size: 325x203mm (12.8x7.99") diag: 383mm (15.1")
ratio: 16:10 modes: max: 1280x800 min: 640x480
API: OpenGL v: 4.5 Mesa 23.1.8-arch1.1 renderer: llvmpipe (LLVM 16.0.6
128 bits) direct-render: Yes
Message: No device data found.
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api with: aoss
Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: Red Hat Qemu virtual
machine type: network bridge driver: piix4_smbus v: N/A modules: i2c_piix4
port: N/A bus-ID: 00:01.3 chip-ID: 8086:7113 class-ID: 0680
Device-2: Red Hat Virtio network driver: virtio-pci v: 1
modules: virtio_pci port: f020 bus-ID: 00:12.0 chip-ID: 1af4:1000
IF: ens18 state: up speed: -1 duplex: unknown mac: <filter>
Local Storage: total: 100 GiB used: 27.27 GiB (27.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: QEMU model: HARDDISK size: 100 GiB
block-size: physical: 512 B logical: 512 B speed: <unknown> tech: N/A
serial: <filter> fw-rev: 2.5+ scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 27.27 GiB (27.3%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 27.27 GiB (27.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-4: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.83 GiB used: 0 KiB (0.0%) priority: 100
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Processes: 184 Uptime: 7m wakeups: 1 Memory: total: 4 GiB
available: 3.83 GiB used: 1.92 GiB (50.2%) Init: systemd v: 254
pm: pacman pkgs: 1731 libs: 502 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-04
Failed units:            lm_sensors.service
p.s. need to leave for a while
Mmm never seen anything like that. That command has been successfully used many times in the past.
Instead of passing the parameter, a config file can be created at /etc/garuda/garuda-update/config that can contain the environment variables in the following format:
SKIP_MIRRORLIST=1
Forthermore, a log is created anyway in /var/log/garuda/garuda-update.
Anyway it has already been fixed.
Just update normally in a while, the time for the mirrors to sync…
