Hello Garuda users.
I recently replace ubuntu and installed Garuda Linux Dragonised KDE on my system. However my observation is that the elantech/ my touchpad driver seems to have a bug perhaps in suspend - resume.
A reboot gets the touchpad to work fine, but after suspending the system and resuming, the touchpad stops working.
Any hints as to what can be done?
sudo garuda-inxi
Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a3eadc67-17e5-4a86-8b24-7b34a01a3003 rw rootflags=subvol=@
Console: pty pts/3 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 82FE v: IdeaPad 5 14ITL05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 14ITL05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN serial: <filter>
UEFI: LENOVO v: FKCN42WW(V3.05) date: 05/16/2022
ID-1: BAT1 charge: 30.0 Wh (56.9%) condition: 52.7/56.5 Wh (93.3%)
volts: 11.8 min: 11.5 model: SMP L19M3PF4 type: Li-ion serial: <filter>
status: not charging cycles: 91
Info: model: 11th Gen Intel Core i5-1135G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check
built: 2020 process: Intel 10nm family: 6 model-id: 0x8C (140)
stepping: 1 microcode: 0xA4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2048 high: 2400 min/max: 400/4200 base/boost: 2300/4200
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 2400 2: 2400 3: 2400 4: 2400 5: 1100 6: 2400
7: 2400 8: 886 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 model: BOE Display 0x08d7 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.2.1
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.38 TiB used: 42.6 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512QFD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 0013P6LN
temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 111d 8h cycles: 512 read-units: 7,904,917
[4.04 TB] written-units: 12,276,256 [6.28 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
ID-1: / raw-size: 85.83 GiB size: 85.83 GiB (100.00%) used: 8.9 GiB (10.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 633 MiB size: 631.8 MiB (99.80%) used: 608 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 111.76 GiB size: 109.44 GiB (97.93%) used: 33.7 GiB
(30.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 85.83 GiB size: 85.83 GiB (100.00%) used: 8.9
GiB (10.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-5: /var/tmp raw-size: 85.83 GiB size: 85.83 GiB (100.00%) used: 8.9
maj-min: 259:5
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 2.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
Src: /sys System Temperatures: cpu: 45.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 289 Uptime: 35m wakeups: 2186 Memory: 15.41 GiB used: 3.03 GiB
(19.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1217 libs: 307
tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: tmux: inxi: 3.3.22
e[1;34mGaruda (2.6.8-1):e[0m
e[1;34m System install date:e[0m 2022-10-16
e[1;34m Last full system update:e[0m 2022-10-18 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Yes
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
