Any ideas / advices how I could make the fan run less using Garuda KDE ?
If I install Garuda XFCE, I do not experience this problem, but with KDE (dragon), the fan of my Yoga laptop is always working more, noisy....
tks !!
tks !!
Garuda Assistant > settings
try using some/all power saving tweaks.
Also in Application menu > fancontrol gui under settings
Please let us know if this solves the problem. It can then be of benefit for others, visiting the forum for answers.
I am trying to find which of the settings helped... IN my 1st test I enabled to many at the same time... Will get back to you...
tks !! Much appreciated....
A tip is...document your changes and test each individually.
