Left Control isn't available with KDE
Good day. Left Control is only available for OS procedures. Not available for games. Is there a way to change that without a big problem?
Please post the terminal output from garuda-inxi as requested in the template of your post.
Of the ten topics you have created so far, four have ended up in the trash because you have consistently ignored the forum rules and the topic template. This topic is now the fifth.
You know the drill:
Issue still unresolved? Then:
  • ONE issue per topic.
  • Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>), or put three tildes (~) above and below the text
You have the option to edit your initial post and add all the necessary information, then you can continue here.
