Heres what ive tried: changing wine version, kernel, DE, and switching from wayland to xorg, so those are not the issue.
When launching a game/application through wine, journalctl gives these logs:
Aug 29 07:51:05 turkey kernel: hid-generic 0003:046D:C339.0021: input,hidraw4: USB HID v1.11 Keyboard [Logitech PRO Gaming Keyboard] on usb-0000:09:00.3-2/input0
Aug 29 07:51:05 turkey kernel: input: Logitech PRO Gaming Keyboard as /devices/pci0000:00/0000:00:07.1/0000:09:00.3/usb3/3-2/
3-2:1.1/0003:046D:C339.0022/input/input87
Aug 29 07:51:05 turkey kernel: hid-generic 0003:046D:C339.0022: input,hiddev98,hidraw5: USB HID v1.11 Keyboard [Logitech PRO
Gaming Keyboard] on usb-0000:09:00.3-2/input1
Spits out a couple of similar logs, so if im not wrong this shows the device "reconnecting"/resetting .
Doesnt effect the current mouse im using, but i think it did sometimes effect my logitech g203 mouse, so maybe its a logitech issue. Never had this issue on vanilla arch, it might have started when i started using garuda but im not sure.
Ive made a post about this problem before, but now i know this isnt a issue with heroic or input-remapper like i thought in my previous post. And i dont think its necessarily a issue with wine.
garuda-inxi:
chicken@turkey ~ garuda-inxi
Kernel: 6.5.0-1-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e6c47e5a-5b6f-44e6-af94-c4a58a25b9a9 rw rootflags=subvol=@
quiet splash vt.global_cursor_default=0 loglevel=2
rd.systemd.show_status=false rd.udev.log-priority=3
sysrq_always_enabled=1 ibt=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F41 date: 07/22/2019
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1537 high: 1550 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1550 2: 1550
3: 1547 4: 1550 5: 1506 6: 1546 7: 1550 8: 1550 9: 1546 10: 1516 11: 1486
12: 1547 bogomips: 81433
vendor: XFX Pine driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 08:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
built: 2022 res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 model: HannSpree/HannStar Hanns.G HH191
serial: <filter> built: 2009 res: 1280x1024 dpi: 86 gamma: 1.2
size: 376x301mm (14.8x11.85") diag: 482mm (19") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon RX 5600 XT (navi10
LLVM 15.0.7 DRM 3.54 6.5.0-1-cachyos) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:ab38
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
Device-3: Kingston HyperX SoloCast
lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 0951:170f class-ID: 0300
API: ALSA v: k6.5.0-1-cachyos status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0029
Local Storage: total: 1.14 TiB used: 860.05 GiB (73.5%)
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: TeamGroup model: TM8PS7256G
tech: SSD serial: <filter> fw-rev: 8B0 scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 26.27 GiB (43.8%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 60 GiB size: 60 GiB (100.00%)
used: 26.27 GiB (43.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C mobo: 42.0 C gpu: amdgpu temp: 55.0 C
mem: 56.0 C
Fan Speeds (rpm): cpu: 1730 mobo: 807 gpu: amdgpu fan: 1095
Power: 12v: N/A 5v: N/A 3.3v: 3.29 vbat: 3.26 gpu: amdgpu watts: 29.00
Processes: 404 Uptime: 9h 33m wakeups: 7 Memory: total: 16 GiB
available: 15.56 GiB used: 6.75 GiB (43.4%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 1706 pm: pacman pkgs: 1688 libs: 398 tools: octopi,paru
pm: flatpak pkgs: 18 Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.29
System install date: 2023-06-13
Last full system update: 2023-08-28
Relevant software: timeshift NetworkManager dracut
