Hello Garuda users.
Kernel: 5.18.14-265-tkg-cacule arch: x86_64 bits: 64 compiler: gcc
v: 12.1.0 parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux518-tkg-cacule
root=UUID=6e008a73-2ead-42e7-b539-bac9a61d3c4f rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2604
date: 02/25/2022
Device-1: ps-controller-battery-4c:b9:9b:6e:47:dc model: N/A serial: N/A
charge: N/A status: charging
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3681 high: 4094 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3788 2: 3605
3: 4094 4: 3598 5: 3658 6: 3649 7: 3662 8: 3717 9: 3600 10: 3605 11: 3599
12: 3599 bogomips: 88799
STIBP: always-on, RSB filling
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA 1
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 09:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 14.0.6 DRM 3.46
5.18.14-265-tkg-cacule)
v: 4.6 Mesa 22.1.4 direct render: Yes
bus-ID: 1-4:2 chip-ID: 054c:0ce6 gen: 4 speed: 16 GT/s class-ID: 0300
lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab38 class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sony DualSense wireless controller (PS5) type: USB
driver: playstation,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.14-265-tkg-cacule running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
Device-2: Sony DualSense wireless controller (PS5) type: USB
driver: playstation,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 054c:0ce6
Local Storage: total: 1.39 TiB used: 830.3 GiB (58.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC
temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
used: 556.9 GiB (58.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 737.8 MiB (4.6%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 49.0 C
mem: 58.0 C
Processes: 324 Uptime: 14m wakeups: 1 Memory: 15.54 GiB
used: 5.86 GiB (37.7%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1951
lib: 496 Shell: Zsh v: 5.9 running-in: dolphin inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2021-12-25
Last full system update: 2022-07-29 ↻
A recent update seems to have broken something.
My Yakuake window is now only 4 lines deep (set at 60% of a 1440 display) and Latte control panels are also much shorter, so the options aren't actually visible. I've already tried resetting configs, which did nothing. Panels like Weather also appear in the wrong place on screen when opened, to the far left rather than directly below the widget
