Hello together,
i have issues with my multi-monitor setup and latte dock.
I have following display setup:
My Problem is, when i maximize the Window on the Screen wit the latte top bar it vanishes behind my top bar and i cant see anything from the tabs of firefox for example.
Maybe this images makes it clearer.
Minimized:
Maximized:
I have allready tried to remove the Window Buttons Applet. But didn´t changed anything.
Any idea how i can fix that?
And is there an option to clone my latte dock and top bar to all monitors?
inxi -Faz
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fd7735f0-481e-4c0e-8b64-770c7e9c3218 rw rootflags=subvol=@
resume=UUID=0b5809f4-ab0b-4fa8-b82f-ed53ec872a1a loglevel=3
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.G0
date: 12/16/2021
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4199 high: 4201 min/max: 2200/4910 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4200 2: 4199
3: 4200 4: 4200 5: 4199 6: 4198 7: 4201 8: 4200 9: 4200 10: 4200 11: 4200
12: 4200 bogomips: 100802
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: ZOTAC
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0
chip-ID: 10de:1f06 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 4352x2160 s-dpi: 91 s-size: 1212x602mm (47.7x23.7")
s-diag: 1353mm (53.3")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: DP-1 res: 1920x1080 hz: 60 dpi: 92
size: 530x300mm (20.9x11.8") diag: 609mm (24")
Monitor-3: DP-2 res: 1152x864 hz: 60 dpi: 29
size: 1020x570mm (40.2x22.4") diag: 1168mm (46")
Monitor-4: DP-4 res: 1280x800 hz: 60 dpi: 89 size: 367x229mm (14.4x9.0")
diag: 433mm (17")
OpenGL: renderer: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:10f9
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel bus-ID: 29:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 4.09 TiB used: 15.07 GiB (0.4%)
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
ID-1: / raw-size: 283.2 GiB size: 283.2 GiB (100.00%)
used: 15.04 GiB (5.3%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
used: 27.9 MiB (7.0%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw-size: 283.2 GiB size: 283.2 GiB (100.00%)
ID-4: /var/log raw-size: 283.2 GiB size: 283.2 GiB (100.00%)
ID-5: /var/tmp raw-size: 283.2 GiB size: 283.2 GiB (100.00%)
ID-1: swap-1 type: partition size: 2.46 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc5 maj-min: 8:37
ID-2: swap-2 type: zram size: 47.03 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 312 Uptime: 16m wakeups: 0 Memory: 47.03 GiB
used: 3.53 GiB (7.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1954 lib: 547 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
