There is a small problem with my latte dock, i had the same issue before and the only fix i could find was to just reinstall. No animations are working, i dont have wobbly windows or minimizing windows looks normal. when i hit the windows button on my keyboard the menu doesnt open up and the latte dock is gone, the only thing i did the day before was use some crypto wallets, play vrchat and update my system(altough im not 100% on that). i tried looking for the issue here but i could find the exact problem i have, the notifications are also shown on the bottom right corner of my desktop now and the top bar is gone too. The background blur is still there however. I have to start every program i want either in explorer or terminal since i cant press windows key.
I tried typing latte-dock --debug and this is what i got:
Icon theme "adwaita" not found.
Icon theme "ubuntu-mono" not found.
Icon theme "yaru" not found.
Icon theme "Mint-X" not found.
Icon theme "elementary" not found.
"An instance is already running!, use --replace to restart Latte"
Additionally the minimize, close and maximise buttons are on the right side instead of the left.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MESSAGES = "en_US.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_CTYPE = "en_US.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_COLLATE = "en_US.UTF-8",Hello.
### Post your terminal/konsole in- and output as text (***no pictures***) from:
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
root=UUID=f614fe14-284d-4ce1-a620-41c5dbee7c8d rw rootflags=subvol=@
Type: Desktop Mobo: NZXT model: N7 B550 serial: <superuser required>
UEFI: American Megatrends v: P1.20 date: 03/02/2021
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: N/A
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3602 high: 3836 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3592 2: 3586
3: 3581 4: 3587 5: 3576 6: 3602 7: 3698 8: 3588 9: 3620 10: 3592 11: 3591
12: 3595 13: 3591 14: 3564 15: 3591 16: 3585 17: 3590 18: 3576 19: 3592
20: 3591 21: 3594 22: 3574 23: 3560 24: 3572 25: 3599 26: 3589 27: 3598
28: 3708 29: 3577 30: 3836 31: 3590 32: 3581 bogomips: 217209
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.0
chip-ID: 10de:2488 class-ID: 0300
loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62")
Monitor-1: DP-0 res: 1920x1080 dpi: 94 size: 521x293mm (20.51x11.54")
diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA RZ04-0318 Gaming Headset [Kraken Ultimate] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4.1:5 chip-ID: 1532:0527
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
IF-ID-2: wgivpn state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-8:6 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 1.36 TiB used: 705.42 GiB (50.5%)
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7
temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 4B6Q
used: 705.42 GiB (75.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): fan-2: 1468 fan-3: 1471 fan-4: 1484 gpu: nvidia fan: 0%
Processes: 509 Uptime: 36m wakeups: 0 Memory: 31.28 GiB
used: 4.29 GiB (13.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2102 lib: 568 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.8-1):
System install date: 2022-02-08
Last full system update: 2022-04-04
