Opening in terminal shows latte-dock is running ... but not showing on screen.
GM
GM
Mostly because of you don't have a dock or a panel.
Type latte-dock --debug
and see what it gives.
"An instance is already running!, use --replace to restart Latte"
What is your latte dock layout?
The original layout was default dragonized. I right-clicked at some point to add a new empty layout.
That is the problem...
It is empty. Why do you expecting it to show anything?
That's true. I've uninstalled/reinstalled, opened ... yet still invisible! Is there a terminal command to initiate a new instance with a default dock?
SOLVED:
killall -9 latte-dock
did the trick.
Thanks for taking the time to help.
GM
