Hello, I have this weird issue where my Latté dock flickers but the flickering is only visible on videos/when I share my screen.
I have tried resetting its config in Garuda Assistant but that didn't help.
Here is a bad video of how it looks for me (left) and how it looks when recording (right):
https://krypt0n.eu/share/latte_bug.mp4
garuda-inxi output:
Kernel: 6.0.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=10754dab-b749-4309-8eb4-01f5e861e31e rw [email protected]
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: ATs product: X-DIABLO GAMER v: X-DIABLO Gamer
serial: <filter> Chassis: type: 3 v: X-DIABLO Gamer serial: <filter>
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: 2021-05-28 serial: <filter>
UEFI: American Megatrends v: 1804 date: 02/02/2021
Info: model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP arch: Zen 3
gen: 4 level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3700 min/max: 2200/4650 boost: enabled
base/boost: 3700/4650 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700 12: 3700
bogomips: 88634
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 08:00.0 chip-ID: 10de:1f08 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 92 s-size: 1590x301mm (62.60x11.85")
s-diag: 1618mm (63.71")
Monitor-1: DP-0 pos: primary,center res: 1920x1080 dpi: 93
Monitor-2: HDMI-0 pos: left res: 1920x1080 dpi: 93
Monitor-3: HDMI-1 pos: right res: 1920x1080 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 1-2:2 v: kernel chip-ID: 3299:4e55 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 08:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SM950 Microphone type: USB
Sound API: ALSA v: k6.0.10-zen2-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
bus-ID: 5-3:4 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 3.64 TiB used: 1.03 TiB (28.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5PSSD8
lanes: 4 type: SSD serial: <filter> rev: P7CR403 temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 21 hrs cycles: 24
read-units: 4,372,574 [2.23 TB] written-units: 3,212,040 [1.64 TB]
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 73d 0h cycles: 724
read-units: 59,374,473 [30.3 TB] written-units: 101,377,772 [51.9 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010A9E680
family: Travelstar 5K1000 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 2.6 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: A560 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 241d 10h cycles: 1248
model: WD10JPCX-24UE4T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 1A01 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 344d 5h cycles: 317
used: 246.09 GiB (26.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.53 GiB used: 1.72 GiB (11.1%)
System Temperatures: cpu: 70.8 C mobo: N/A gpu: nvidia temp: 58 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 388 Uptime: 5h 41m wakeups: 0 Memory: 15.53 GiB
used: 9.11 GiB (58.7%) Init: systemd v: 252 default: graphical
pkgs: 2158 libs: 554 tools: octopi,pamac,paru pm: appimage pkgs: 0
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-10-12
Last full system update: 2022-11-28 ↻
Windows dual boot: Yes
Failed units: plymouth-deactivate.service plymouth-start.service
