Hello,
╭─renato@81v7 in ~
╰─λ garuda-inxi
Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=08a0ce24-da0c-4b98-b595-99178c85571b rw rootflags=subvol=@
resume=UUID=a2824beb-450e-4551-aab0-db417ce1a51f loglevel=3
Type: Laptop System: LENOVO product: 81V7 v: Lenovo IdeaPad S145-15API
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S145-15API
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679WIN
serial: <superuser required> UEFI: LENOVO v: BUCN29WW date: 05/14/2021
ID-1: BAT0 charge: 16.9 Wh (56.5%) condition: 29.9/30.0 Wh (99.8%)
volts: 7.5 min: 7.4 model: LGC L16L2PB2 type: Li-poly serial: <filter>
status: N/A cycles: 22
Info: model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1738 high: 2054 min/max: 1400/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2054 2: 1444
3: 1863 4: 1591 bogomips: 20760
STIBP: disabled, RSB filling
vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 174f:1176 class-ID: 0e02
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN DRM 3.44.0
5.16.13-zen1-1-zen LLVM 13.0.1)
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2:3
chip-ID: 0cf3:e500 class-ID: e001
address: <filter>
Local Storage: total: 253.39 GiB used: 22.46 GiB (8.9%)
model: MZALQ256HAJD-000L2 size: 238.47 GiB block-size: physical: 512 B
rev: AL2QFXV7 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: DT 101 G2
size: 14.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 22.46 GiB (9.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 5.73 GiB used: 204 MiB (3.5%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 245 Uptime: 2h 12m wakeups: 92 Memory: 5.73 GiB
used: 3.28 GiB (57.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1865 lib: 549 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-11
Last full system update: 2022-03-11
In several installations, be it after the first system update or after a few, the green dragon character from the Latte Dock when no app is maximized disappears and is substituted for an empty white box.
How can I fix it?
