latte doesn't work after system update and kwin x11 crashes how do i fix it?
You have three options
1.restore the snapshot
2.create new user
3.remove the ~/.config directory
Some configs have been corrupted
Also, if you are using Event Calendar widget, this stopped working with the new kwin/QT recent updates and causes Latte and plasma desktop to crash. So, if you are using it, remove it from the taskbar, and uninstall it.
There is no taskbar ![]()
work but not so nice like before.
You can manually uninstall it via .local/share/plasma/plasmoids/ search for event calendar and delete it, then reboot.
Above I was kidding ->
but the reddit thread point to that path too and I have no /plasma folder there only plasma_notes.
I remove also eventcalendar but that doesn't help too.
So I use my i3wm and be fine
CU
Had the same problem. Also if the user has no administraion rights, than everything is working.
You can try to login with guest account. There should no chrashes.
Before updating i changed the latte theme from garude to another one. Than update everything and had no chrashes.
