Hello Garuda users.
The problem started with this post How to stop settings from randomly changing? but as the wouldn't be much of a problem if i could just normally change Latte-dock back but it at least the one on the bottom isn't editable. I can change the settings but i just doesn't change and stays stuck looking like the indicator selectore where on Win10 but as you see its on Plasma.
I already tried to use garuda assistant to rest latte but that just resets the apps to default, garuda-update also didnt help. Last thing i tried was setting up a vm with a fresh install of garuda and took a backup with Plasma config saver to try to load it but that also didnt work. Any cluw what else i could try?
Edit: I also tried reinstalling the package
Kernel: 5.17.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f181ffc3-cea3-4242-9c63-210fcfa3609e rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 amd_iommu=on iommu=pt
video=efifb:off
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DV_FX505DV v: 1.0
Mobo: ASUSTeK model: FX505DV v: 1.0 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: FX505DV.312 date: 01/28/2021
ID-1: BAT0 charge: 32.9 Wh (87.3%) condition: 37.7/48.1 Wh (78.4%)
volts: 11.5 min: 11.7 model: FX50442 type: Li-ion serial: N/A
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1272 high: 1523 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1222 2: 1222
3: 1221 4: 1208 5: 1325 6: 1240 7: 1221 8: 1523 bogomips: 33538
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f11
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 5-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: amdgpu
Monitor-1: eDP-1 model: Najing CEC Panda 0x002d built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 13.0.1 DRM 3.44
5.17.8-zen1-1-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
Sound Server-1: ALSA v: k5.17.8-zen1-1-zen running: yes
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 284.8 GiB (59.7%)
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
rev: P1MA0V4 temp: 48.9 C scheme: MBR
ID-1: / raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
used: 284.8 GiB (59.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-3: /var/log raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-4: /var/tmp raw-size: 476.93 GiB size: 476.93 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.2 GiB used: 87 MiB (1.2%) priority: 100
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 282 Uptime: 14m wakeups: 2 Memory: 7.2 GiB
used: 3.33 GiB (46.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1776 lib: 495 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.3-2):
System install date: 2021-11-08
Last full system update: 2022-05-18
Snapshots: Timeshift
