Hello!
I've recently installed Gaurda and I've noticed that the latte-dock panel is bugged. I use two screens and I have the panel on the left sides of both screens, with the justified allignement and dodge active settings. While the panel from my left screen works perfeclty, the one in my right screen its bugged. When it has to dodge, it will dodge to the right side of my left screen and enter in a loop where it goes from the left part of my right screen to the right part of my left screen and so on, and it will never dodge. It happens with every window but only with the justified allignment, as it works perfectly fine when I set a dock in every allignment, or the panel justified to the center or top/bottom of the screen. I set the dock settings since I were not able to fix it reinstalling latte or changing other settings.
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=687c1e5f-6fd1-49db-8c68-ddf00ee5bac9 rw [email protected]
resume=UUID=eef151b2-ca3b-4eda-9dd7-3b73fb9f3938 loglevel=3 ibt=off
Type: Laptop System: Micro-Star product: GS66 Stealth 10SE v: REV:1.0
serial: Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-16V1 v: REV:1.0 serial:
UEFI: American Megatrends v: E16V1IMS.112 date: 11/19/2020
ID-1: BAT1 charge: 84.3 Wh (100.0%) condition: 84.3/95.0 Wh (88.7%)
volts: 16.9 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2438 high: 4800 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 2300 6: 2300 7: 2300 8: 2300 9: 2300 10: 4800 11: 2300 12: 2300
13: 2017 14: 2300 15: 2300 16: 2300 bogomips: 73598
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:5
chip-ID: 5986:2127 class-ID: 0e02 serial:
Device-4: MacroSilicon USB Video type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-4:2
chip-ID: 534d:2109 class-ID: 0300
Display: x11 server: [X.Org](http://X.Org) v: 21.1.5 with: Xwayland v: 22.1.6
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: left res: 1920x1080 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
Monitor-2: eDP-1 pos: primary,right res: 1920x1080 hz: 240 dpi: 142
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics (CML GT2)
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-4:2
alternate: snd_soc_skl,snd_sof_pci_intel_cnl chip-ID: 534d:2109
class-ID: 0300 bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
Device-3: MacroSilicon USB Video type: USB
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
IF: wlo1 state: up mac:
Device-2: Intel driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 3d:00.0 chip-ID: 8086:3101 class-ID: 0200
IF: enp61s0 state: down mac:
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Local Storage: total: 1.84 TiB used: 341.94 GiB (18.1%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: rev: 2B4QFXO7 temp: 41.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1032 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: 11111000 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
used: 341.94 GiB (38.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
ID-4: /var/log raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.94 GiB size: 896.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.16 GiB used: 1.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.28 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
System Temperatures: cpu: 71.0 C pch: 47.0 C mobo: N/A
Processes: 383 Uptime: 2m wakeups: 2 Memory: 31.16 GiB
used: 3.98 GiB (12.8%) Init: systemd v: 252 default: graphical
pkgs: 2066 libs: 558 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-14
Last full system update: 2022-12-16
