╰─λ garuda-inxi
Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=ba2fb729-b4b9-49f0-8223-47f0378d19c9 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: ROG Strix G513QM_G513QM v: 1.0
Mobo: ASUSTeK model: G513QM v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: G513QM.314 date: 09/03/2021
ID-1: BAT0 charge: 23.1 Wh (29.0%) condition: 79.7/90.0 Wh (88.5%)
volts: 14.5 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3300 min/max: 1200/4889 boost: enabled
base/boost: 3300/4650 scaling: driver: acpi-cpufreq governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3300 2: 3300 3: 3300 4: 3300
5: 3300 6: 3300 7: 3300 8: 3300 9: 3300 10: 3300 11: 3300 12: 3300
13: 3300 14: 3300 15: 3300 16: 3300 bogomips: 105402
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1638
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.13-zen1-1-zen LLVM 13.0.1)
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 1.4 TiB used: 337.51 GiB (23.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SK Hynix model: HFM001TD3JX013N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41000C20
temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 110d 23h cycles: 4,488
read-units: 8,318,059 [4.25 TB] written-units: 10,393,032 [5.32 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW512G8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 205d 16h cycles: 6,263
read-units: 64,392,834 [32.9 TB] written-units: 63,688,273 [32.6 TB]
ID-1: / raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
used: 337.49 GiB (70.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p1
maj-min: 259:1
used: 25.5 MiB (26.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:3
ID-3: /home raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
maj-min: 259:1
ID-4: /var/log raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
maj-min: 259:1
ID-5: /var/tmp raw-size: 476.94 GiB size: 476.94 GiB (100.00%)
maj-min: 259:1
ID-1: swap-1 type: zram size: 15.12 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: 56.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): cpu: 0
Processes: 419 Uptime: 21m wakeups: 13 Memory: 15.12 GiB
used: 4.46 GiB (29.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1842 lib: 552
inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-21
Last full system update: 2022-03-12
Windows dual boot: Yes
Every few days latte-dock seems to break and I have to reset it. I don't change anything on the default settings except removing a few things from the dock at the bottom. I reset everything again today and tried to check the Dragonized theme settings and noticed this.
