Hey there,
trying to fix the Wayland boot issue, @dejv78 and I have decided to reinstall our systems.
After that finished for me, I was finally able to boot into wayland, but now there is a new problem: Latte dock won't start.
It always spits out this error: interface 'kde_output_device_v2' has no event 14
Note: I am using the kde git packages.
Why is that?
Thanks!
Inxi:
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6e6211b4-cfb4-44c0-8970-5e4a826e0c5e rw rootflags=subvol=@
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_wayland vt: 2 dm: Ly
Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50a
date: 11/27/2019
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3029 high: 4239 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2572 2: 2795
3: 2438 4: 2432 5: 2717 6: 4239 7: 3220 8: 2848 9: 2424 10: 2604 11: 3827
12: 4236 bogomips: 86224
STIBP: disabled, RSB filling
Device-1: AMD Baffin [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 08:00.0 chip-ID: 1002:67ff class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-3:5 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: wayland server: X.Org 1.21.1.4 compositor: kwin_wayland driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Screen-1: 0 s-res: 3600x1200 s-dpi: 96 s-size: 953x318mm (37.5x12.5")
s-diag: 1005mm (39.6")
Monitor-1: XWAYLAND0 res: 1680x1050 hz: 60 dpi: 91
size: 470x300mm (18.5x11.8") diag: 558mm (22")
Monitor-2: XWAYLAND1 res: 1920x1200 hz: 60 dpi: 100
size: 490x310mm (19.3x12.2") diag: 580mm (22.8")
OpenGL: renderer: AMD Radeon RX 560 Series (POLARIS11 DRM 3.42.0
5.15.11-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 08:00.1
chip-ID: 1002:aae0 class-ID: 0403
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media USB Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:6 chip-ID: 0d8c:9700
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 03:00.0
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 3-1.1:4 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
address: <filter>
Local Storage: total: 2.96 TiB used: 1.02 TiB (34.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A82 scheme: GPT
ID-1: / raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
used: 28.62 GiB (14.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 576 KiB (0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%)
used: 136.83 GiB (18.6%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.36 GiB used: 2.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1410
Processes: 406 Uptime: 15m wakeups: 0 Memory: 31.36 GiB
used: 6.14 GiB (19.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: apt: 0 pacman: 2018 lib: 481
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: alacritty
inxi: 3.3.11
