╭─[email protected] in ~ via v3.10.8 as 🧙 took 2m42s
[🔴] × garuda-update -- ttf-firacode-nerd nerd-fonts-fantasque-sans-mono ttf-font-nerd
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1995.0 KiB 3.10 MiB/s 00:01 [--------------------------------] 100%
blackarch is up to date
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda 95.7 KiB 131 KiB/s 00:01 [--------------------------------] 100%
core 157.7 KiB 382 KiB/s 00:00 [--------------------------------] 100%
extra 1759.9 KiB 2.20 MiB/s 00:01 [--------------------------------] 100%
community 7.2 MiB 5.60 MiB/s 00:01 [--------------------------------] 100%
multilib 167.5 KiB 405 KiB/s 00:00 [--------------------------------] 100%
chaotic-aur 1995.0 KiB 1742 KiB/s 00:01 [--------------------------------] 100%
blackarch 3.7 MiB 4.10 MiB/s 00:01 [--------------------------------] 100%
spawn pacman -Su ttf-firacode-nerd nerd-fonts-fantasque-sans-mono ttf-font-nerd
:: There are 14 providers available for ttf-font-nerd:
:: Repository community
1) ttf-arimo-nerd 2) ttf-firacode-nerd 3) ttf-hack-nerd 4) ttf-iosevka-nerd
5) ttf-nerd-fonts-symbols-1000-em 6) ttf-nerd-fonts-symbols-1000-em-mono
7) ttf-nerd-fonts-symbols-2048-em 8) ttf-nerd-fonts-symbols-2048-em-mono
9) ttf-nerd-fonts-symbols-common 10) ttf-sourcecodepro-nerd 11) ttf-terminus-nerd
12) ttf-ubuntumono-nerd
:: Repository chaotic-aur
13) nerd-fonts-fantasque-sans-mono 14) nerd-fonts-jetbrains-mono
Enter a number (default=1): 1
I'm having the same issue and I'm using the new garuda-update? I'm on LxQt.
[[email protected] ~]$ garuda-update
core 157.7 KiB 140 KiB/s 00:01 [---------------------------------------] 100%
extra 1759.9 KiB 811 KiB/s 00:02 [---------------------------------------] 100%
chaotic-aur is up to date
garuda 95.8 KiB 20.5 KiB/s 00:05 [---------------------------------------] 100%
core 157.7 KiB 205 KiB/s 00:01 [---------------------------------------] 100%
extra 1759.9 KiB 471 KiB/s 00:04 [---------------------------------------] 100%
community 7.2 MiB 781 KiB/s 00:09 [---------------------------------------] 100%
multilib 167.5 KiB 96.8 KiB/s 00:02 [---------------------------------------] 100%
chaotic-aur 2005.4 KiB 175 KiB/s 00:11 [---------------------------------------] 100%
spawn pacman -Su
:: Replace nerd-fonts-fira-code with community/ttf-firacode-nerd? [Y/n] y
resolving dependencies...
:: removing nerd-fonts-fira-code breaks dependency 'nerd-fonts-fira-code' required by garuda-lxqt-kwin-settings
Here's the output from my latest test of Garuda welcome
:: Synchronising package databases...
garuda 95.8 KiB 2.97 KiB/s 00:32 [------------------------------------] 100%
core is up to date
extra 1759.9 KiB 187 KiB/s 00:09 [------------------------------------] 100%
community 7.2 MiB 227 KiB/s 00:32 [------------------------------------] 100%
chaotic-aur 2012.3 KiB 272 KiB/s 00:07 [------------------------------------] 100%
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : SSL connection timeout
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : Failed to connect to cdn-mirror.chaotic.cx port 443 after 9829 ms: Couldn't connect to server
error: failed retrieving file 'chaotic-aur.db' from cdn-cn-mirror.chaotic.cx : Resolving timed out after 10000 milliseconds
garuda 95.8 KiB 18.4 KiB/s 00:05 [------------------------------------] 100%
core 157.7 KiB 156 KiB/s 00:01 [------------------------------------] 100%
extra 1760.2 KiB 140 KiB/s 00:13 [------------------------------------] 100%
community 7.2 MiB 242 KiB/s 00:30 [------------------------------------] 100%
multilib 167.5 KiB 193 KiB/s 00:01 [------------------------------------] 100%
chaotic-aur 2012.3 KiB 253 KiB/s 00:08 [------------------------------------] 100%
error: failed retrieving file 'garuda.db' from geo-mirror.chaotic.cx : SSL connection timeout
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : Failed to connect to saturn.dedyn.io port 443 after 5200 ms: Couldn't connect to server
error: failed retrieving file 'garuda.db' from cdn-mirror.chaotic.cx : Failed to connect to cdn-mirror.chaotic.cx port 443 after 9621 ms: Couldn't connect to server
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : Failed to connect to cdn-mirror.chaotic.cx port 443 after 8800 ms: Couldn't connect to server
error: failed retrieving file 'garuda.db' from cdn-cn-mirror.chaotic.cx : Failed to connect to cdn-cn-mirror.chaotic.cx port 443 after 9408 ms: Couldn't connect to server
spawn pacman -Su
Packages (9) garuda-gnome-settings-1.4.1-2 gnome-shell-1:43.1-2 lib32-libx11-1.8.2-1 libutf8proc-2.8.0-1
nerd-fonts-fira-code-2.2.2-1 [removal] nmap-7.93-1 subversion-1.14.2-1
ttf-firacode-nerd-2.2.2-2 unrar-1:6.2.2-1
Total Download Size: 17.81 MiB
Total Installed Size: 87.84 MiB
Net Upgrade Size: 0.33 MiB
Would you like to explain? You should not be using yay to update your system, the correct syntax for updating your system as well as aur packages would be garuda-update -a.
