Not sure if this is done correctly. I believe all the info is pasted that is required? If more info is needed. let me know and i'll provide it as quickly as i can.
Logs for crash: 13:21:31 NetworkManager: <info> [1669753291.4445] dhcp4 (eno1): state changed n - Pastebin.com
Garuda-inxi
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=994161d7-089c-435c-983f-37ea442d1ba2 rw rootflags=subvol=@
resume=UUID=5402b55d-ab34-4ae7-8419-7ba16828fb32 loglevel=3
Desktop: Cinnamon v: 5.4.12 tk: GTK v: 3.24.34 wm: Mutter vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: AB350-Gaming 3 v: N/A
Mobo: Gigabyte model: AB350-Gaming 3-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F52h date: 07/27/2022
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2221 high: 2792 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2196 2: 2195
3: 2200 4: 2200 5: 2200 6: 2196 7: 2200 8: 2200 9: 2200 10: 2085 11: 2200
12: 2792 13: 2200 14: 2196 15: 2198 16: 2200 17: 2200 18: 2200 19: 2196
20: 2200 21: 2200 22: 1861 23: 2200 24: 2605 bogomips: 182053
protection
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1, DP-2, DP-3, HDMI-A-1 empty: none
bus-ID: 09:00.0 chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1:2 chip-ID: 046d:085c
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x572mm (60.00x22.52")
s-diag: 1628mm (64.09")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,bottom-c
model: BenQ RL2455 serial: <filter> built: 2015 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Monitor-2: DP-2 mapped: DisplayPort-1 pos: top-right model: AOC 2269W
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
Monitor-3: DP-3 mapped: DisplayPort-2 pos: bottom-l model: Asus VS247
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-4: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: AOC 2269W
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 5700 XT (navi10
LLVM 14.0.6 DRM 3.48 6.0.9-zen1-1-zen) direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 3-1:2 pcie: gen: 4 chip-ID: 046d:085c class-ID: 0102 speed: 16 GT/s
serial: <filter> lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab38
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: Astro Gaming MixAmp Pro type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 9886:0018
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-1:2 chip-ID: 0bda:2550 class-ID: e001 serial: <filter>
Local Storage: total: 7.62 TiB used: 184.59 GiB (2.4%)
rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
model: WD20EARX-32PASB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: AB51
scheme: MBR
model: WD5001FZWX-00ZHUA0 size: 4.55 TiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Patriot model: Spark size: 119.24 GiB
serial: <filter> rev: 60.9 scheme: GPT
ID-1: / raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
used: 184.59 GiB (20.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-4: /var/log raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 43.0 C
mem: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 966
Processes: 486 Uptime: 8m wakeups: 0 Memory: 31.27 GiB
used: 7.39 GiB (23.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: 1466 pm: pacman pkgs: 1460
libs: 402 tools: paru pm: flatpak pkgs: 6 Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-18
Last full system update: 2022-11-25
